> Interesting v8 conversion on ebay, Mid radiator, Tornado trani
Andyrew
post Jul 27 2014, 12:49 AM
Spooling.... Please wait
Check this out guys
http://www.ebay.com/itm/Porsche-914-Speeds...=US_Cars_Trucks
The radiator setup and Tornado trani are wild!
mgp4591
post Jul 27 2014, 01:19 AM
The Toronado Turbo 425 transaxle puts the drive axle almost thru the center of the oil pan, so if the 914 axles are at an angle forward at the differential you still have alot of weight in a bad spot. Trailing throttle oversteer anyone? Plus 425 is a variation on the TH400 automatic trans with a transfer case type drive off the back, then it has a shaft going forward to the diff then out to axle flanges where the axles bolt on. It's a very heavy setup turning your 914 into a pendulum that makes a 911 look inherently balanced. It's an interesting conversion but not one I'd want. If you're going an engine/transaxle combo that works and is lighter, go transverse with a Honda FWD setup. Same work, weight is more forward with alot of aluminum and more currently serviceable. Call it a Pornda if you'd like... better combination than a Poronado! (IMG:style_emoticons/default/shades.gif)
TheCabinetmaker
post Jul 27 2014, 06:09 AM
I drive my car everyday
Guy doesn't even know what he's selling. It's a trans from a tor"O"nado. As in an Oldsmobile.
arkitect
post Jul 27 2014, 07:03 AM
Those engines must be heavy, the car sits with the front high. Big gap between front wheels and fender. A lot of work for a crazy conversion.
Dave
- Lo-Fi Version Time is now: 2nd April 2026 - 08:53 AM
