| bandjoey |
Jul 24 2015, 09:55 AM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
For home painters. I've been wondering what compressor size is needed for painting and found this. Air compressors Explained and Tested.
https://m.youtube.com/watch?feature=em-subs...p;v=cqae1rEwIKw Ok I've played with embedding this and it doesn't work. I used the 'help' and couldn't make it work. Thanks Please fix and post below how you made it work. |
| Chris H. |
Jul 24 2015, 10:32 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
| Chris H. |
Jul 24 2015, 10:36 AM
So you just need the embed code which is the code after v= but before the &app in this case. yours is cqae1rEwIKw Click the URL and you will see it towards the end.
To post a vid you put... youtube in brackets first [] then the embed code with no spaces, then /youtube in brackets [] Try it! |
| Mark Henry |
Jul 24 2015, 01:01 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I don't have time to look at the links, but I'd get the biggest you can afford. Personally I wouldn't get under a 5hp/60-gal.
| ThePaintedMan |
Jul 24 2015, 01:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
I don't have time to look at the links, but I'd get the biggest you can afford. Personally I wouldn't get under a 5hp/60-gal. (IMG:style_emoticons/default/agree.gif) You can paint a car with a very small compressor. But that doesn't say anything about how nice it is to have a DA for sanding... which will make even the best compressors do some work. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:39 AM |
