| nocones |
Aug 4 2004, 08:08 PM
Sportscar lunatic ![]() ![]() Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
I'm trying to replace the electical portion of the ignition switch. I've got the steering wheel, lock nut, switchs, and ignition retaining plate off. I cannot however slide the ignition switch assembly out. Is there something else I am missing?
Do I have to remove the upper steering shaft? (first U-joint back) Thanks. Michael (IMG:style_emoticons/default/monkeydance.gif) 74' 914/8 |
| Brad Roberts |
Aug 4 2004, 08:10 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
There is a spring clip in the side of the ignition housing that you need to push on...
B |
| nocones |
Aug 4 2004, 08:24 PM
Is that in the ignition switch itself? (ie. to remove the electrical portion from the tumbler/key portion)
Or to remove the entire assembly from the housing? Michael (IMG:style_emoticons/default/monkeydance.gif) 74' 914/8 |
| Brad Roberts |
Aug 4 2004, 08:32 PM
Oh.. dont forget about the tiny flat blade screw...
I'm trying to find a pic for you.. I may have to shoot one real quick. B |
| nocones |
Aug 4 2004, 08:46 PM
Okay, found the spring clip to remove the tumbler portion. Managed to remove from steering column.
Found the tiny flat blade screw and got the little electical part out. (Also managed to NOT lose the tiny little spring hiding inside) Problem, they sold me the wrong part. (IMG:style_emoticons/default/headbang.gif) The plastic housing on the one I got is the wrong shape, but has the correct connectors, mounting, etc... I guess it's back to the parts house tomorrow. Michael (IMG:style_emoticons/default/monkeydance.gif) 74' 914/8 |
| Brad Roberts |
Aug 4 2004, 08:48 PM
Cool. Glad you got it.
There is another V8 914 guy in Santa Rosa.. works for "Firemans Fund" in Novato. I think his name is "Nick". I bought a car from him a few years back. B |
| nocones |
Aug 4 2004, 09:01 PM
Thanks for the help Brad.
Hopefully I can find the correct part tomorrow. Michael (IMG:style_emoticons/default/monkeydance.gif) 74' 914/8 |
| nocones |
Aug 5 2004, 10:00 AM
Okay, here is some additional info for anyone who may find this in a search later.
Link to ignition switch "how to" article http://www.pelicanparts.com/techarticles/9...tion_switch.htm PN: 111-905-865K Where to get it: http://www.pelicanparts.com/catalog/shopca..._electr_pg4.htm Don't want this to look like an ad for these guys, they just happen to have the info posted. The switch is interchangable with the same year VW Bug. NOT interchangable with the VW Rabbit (this is the part I was sold by mistake) Happy wrenching! Michael (IMG:style_emoticons/default/monkeydance.gif) 74' 914/8 |
| Dave_Darling |
Aug 5 2004, 12:30 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Note that the article is only good for the 72-74 switch. The 70-71 is different, as is the 75-76, and the procedure is slightly different in each case.
And I have no idea what the differences actually are.... --DD |
| Graham |
Sep 26 2004, 08:53 AM
Newbie ![]() Group: Members Posts: 2 Joined: 26-September 04 From: San Diego, CA Member No.: 2,832 |
I am having a similar problem to the issues described in this thread. I need to replace the ignition switch (electrical part) on my '75. I have the wheel and the switch assembly off, and I discovered how to remove the key/tumbler part, but I cannot for the life of me see how to get to the electrical part and the small set screw being mentioned. It is covered by the black plastic shroud which I cannot see how to remove. What am I missing?
Graham |
| brant |
Sep 26 2004, 11:34 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Bump,
welcome Graham... you may need to start a new thread to catch peoples attention again... I've noticed after people have already read through the beginning of a thread and it doesn't apply to them, they may not catch all of the new posts... sorry I haven't been able to answer your questions on this one. good to see you here brant |
| BMartin914 |
Sep 27 2004, 12:53 PM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Graham,
I JUST did this saturday to remove a melted one from my 75. All I did was remove the wheel and then the turn signal/ wiper stalk assembly. Next you have to remove the retainer collar that holds the bearing in place and if all of the harnesses are undone, the assembly should slide off of the column. Once you have it off, come in from the back and remove the set screw -- its very obvious, and the piece will come out. Once you do it once you can do it 1000 times. Good luck, hope this helps. Ben |
| Graham |
Sep 27 2004, 11:22 PM
Thanks, Ben, it worked great! Actually, I had to take off two clips, but after that it came off just fine.
Graham |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:57 AM |
