| bretth |
Jan 12 2016, 06:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Looking very cool. I've also had the eye Dr. drill my eye with that dremel looking tool to harvest rust from my eye. Be sure to do all of your antibiotic eye drops.
Brett |
| JeffBowlsby |
Jan 12 2016, 07:12 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Want. (IMG:style_emoticons/default/smilie_pokal.gif)
| Unobtanium-inc |
Jan 12 2016, 10:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,448 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None
Looking very cool. I've also had the eye Dr. drill my eye with that dremel looking tool to harvest rust from my eye. Be sure to do all of your antibiotic eye drops. Brett Man, I've been using the eye drops around the clock, I don't want to see any more eye Dr's anytime soon. |
| Unobtanium-inc |
Jan 13 2016, 11:47 AM
Hey everyone, I don't need the motor I pulled out of the donor car. So it's FREE, pickup only at my shop in Ravena, NY.
Happy new Year- Adam Attached thumbnail(s) |
| bretth |
Jan 13 2016, 12:53 PM
| Unobtanium-inc |
Jan 13 2016, 02:41 PM
Brett, it's yours, I already answered your PM.
Brett said he is going to bring me chili, now that's worth it's weight in gold! |
| bretth |
Jan 13 2016, 06:18 PM
| Unobtanium-inc |
Jan 15 2016, 06:41 PM
Well, looks like a no-go on the off the shelf Dual A-arm setups. The Mendeola guys didn't respond when I asked if it would work for my project but the guy from EyeBall Engineering, who sells a similar setup was nice enough to get back with a very refreshing and honest answer.
"hi in a word no,but anything is possible with enough money the old saying goes speed costs money,how fast do you want to go? thanks bruce" I can only assume the answer would have been the same from Mendeola, which is why they didn't bother to respond. Either way neither system will work as far as I know, so I'm back to my own engineering. I had already planned to lower the shock towers in the rear but I guess I'm going to try for the shorter shock in the front. I'm confident I can make it work. |
| Phoenix-MN |
Jan 15 2016, 09:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Get your engineering hat on (IMG:style_emoticons/default/biggrin.gif) I've been doing a bunch of renditions in my CAD program using modified corvette C4 control arms and modified 911 struts. More than one way to skin a cat (IMG:style_emoticons/default/idea.gif)
| Chris914n6 |
Jan 16 2016, 02:36 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Look into 944 front spindles, uses same rotors and [mostly] same hubs as 911, and run separate coilovers. You could likely adapt the 944 lower arms (and balljoints) easily also.
| Unobtanium-inc |
Jan 16 2016, 06:55 PM
Thanks guys for the ideas!
| Mark Henry |
Jan 16 2016, 07:58 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I think some use the A-arm parts off of a Opal.
There is a thread somewhere on the samba where a guy built his own A-arm from scratch, but right now all I can find is off-road set-ups. |
| Mark Henry |
Jan 16 2016, 08:03 PM
| Mark Henry |
Jan 16 2016, 08:09 PM
Mustang 2 on a type 1 beetle pan
http://www.sterlingkitcars.com/members_n_f...beetle-pan.html http://www.heidts.com/part/mustang-2-front-suspension-ifs/ |
| Mark Henry |
Jan 16 2016, 08:18 PM
| Mark Henry |
Jan 16 2016, 08:26 PM
A search on the Germanlook suspension forum to look through.
http://www.germanlook.net/forums/search.php?searchid=290023 |
| gereed75 |
Jan 16 2016, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Not sure why mendeola would not work. They have various widths and various hubs for VW wide five and Porsche 944 I believe. I would not pass this by without more thorough consideration.
Just figuring out to weld it in would be the trick. You got the fab/welding skills. |
| porschetub |
Jan 17 2016, 12:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Reduced height type 1 super beetle struts/hubs (redrilled) maybe should be a similar spring rate have no idea if they will work.
just putting it out there,cheers |
| veekry9 |
Jan 17 2016, 08:15 AM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
http://www.ddk-online.com/phpBB2/viewtopic...28&start=15
Some solutions from England. Books for the builder: 1) Build Your Own Sports Car by Ron Champion 2) Competition Car Composites by Simon McBeath 3) Race and Rally Source Book by Allan Staniforth 4) Competition Car Suspension by Allan Staniforth 5) How to Build Motorcycle engine Racing Cars' by Tony Pashley http://www.amazon.ca/s/ref=nb_sb_noss?url=...by+Ron+Champion http://thebargeots.free.fr/documents/Compe..._Suspension.pdf http://www.962and904.com/ http://www.fsae.com/forums/showthread.php?...examples-anyone http://www.wwufsae.com/Shared_FSAE_CAD_Library/ |
| Unobtanium-inc |
Jan 17 2016, 09:57 AM
This was the response from Bruce at Eyeball, a very honest answer, and much appreciated. "hi in a word no,but anything is possible with enough money the old saying goes speed costs money,how fast do you want to go? thanks bruce " |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:45 AM |
