| veekry9 |
Feb 10 2016, 04:25 AM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
https://www.youtube.com/watch?v=3O-Ol2OmZxg In your neck of the woods,a good choice in a one stop shopping trip is the Eastwood line of products. Rust prepping, rust neutralizing, more prepping, masking. epoxy primer, sanding, masking, more primer, sanding, masking, color dusting, color coating, sanding, buffing, polishing, gleaming. A lot of work,you have to be prepared to be diligent in the details. It's the why of automotive body and painting costs,a lot of work. http://www.eastwood.com/paints/2k-aero-spray-paints.html https://www.google.ca/webhp?sourceid=chrome...t+supply+oregon Did I mention sanding? First. Try out your skills on a old rusted fender,2 square yards. If you can,with the labor you supply,bring it back to a finish that everyone says is beautiful,why then proceed with the 914. (IMG:style_emoticons/default/biggrin.gif) |
| Mikey914 |
Feb 10 2016, 09:32 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Told him to try cleaning with simple green 1st. There is a steam cleaner so that will help. See what you have before you make too many plans. It may mostly clean up nice, but I'm thinking the about of work needed is minimal . It looked pretty solid.
| Dave_Darling |
Feb 10 2016, 06:13 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
So I need to expect that at some point I will need to have some engine work. Does the engine grenade or will that case be reusable? Just replace the heads? If you're talking about the failure mode from thin barrels, then I would guess that the most likely one is that you start getting combustion gases blowing out around the seal there, burning away part of the head and part of the cylinder. Unlikely to affect the bottom end, but sometimes stuff does happen. --DD |
| Matty900 |
Feb 11 2016, 01:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I was able to get a better look at the car today. It really is pretty solid. I did get some better pictures of it and in looking at the hell hole, I can see that the rust has go all the way through the metal in some pin holes.
Attached thumbnail(s) |
| Matty900 |
Feb 11 2016, 01:48 AM
I am not sure what rust issues I may have inside the longs.hopefully it is not too bad under the rocker pannels
| Matty900 |
Feb 11 2016, 01:51 AM
Took off the rocker pannels and there was lots of dirt. (Thankfully very dry dirt) the rest looks great
Attached thumbnail(s) Attached image(s)
| Matty900 |
Feb 11 2016, 10:14 PM
What is the best way to take care of this level of rust in the hell hole? Who do you prefer to get the metal from, or do you just make your own patch for this?
| Matty900 |
Feb 18 2016, 12:57 AM
Decided to go ahead and fix the damaged fender and minor dings aroundthe body and paint the car. So I guess this is project thread now.
| Matty900 |
Feb 18 2016, 01:01 AM
Everything is coming apart nicely.
| Matty900 |
Feb 18 2016, 01:08 AM
Getting ready to steam clean everything.
| Matty900 |
Feb 18 2016, 01:17 AM
Very nice red breaks. I guess there was some leftover in the can after the fender. Sent these off to Eric at PMB. Will be replacing breaks, bearings and suspension all the way around.
Now I just need to find a factory front swaybar. Anyone have one they are willing to part with? Attached thumbnail(s) |
| Matty900 |
Feb 18 2016, 04:51 PM
Steam cleaning today
| Matty900 |
Feb 18 2016, 10:47 PM
Few more photos from today
| Krieger |
Feb 19 2016, 12:04 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Nice find! Add the Vin to our data base.
| Matty900 |
Mar 8 2016, 08:41 PM
(IMG:style_emoticons/default/piratenanner.gif) Hell hole fixed!
| cwpeden |
Mar 8 2016, 10:26 PM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Nice progress, looks like you have a mix of long and short wheel bolts. If you run the fuchs make sure to find a full set of long bolts.
| hot_shoe914 |
Mar 9 2016, 08:57 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
| Hank914 |
Mar 9 2016, 10:34 PM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I'll never understand how people find these cars... I am considering buying a 75 garage find with only 23K miles on it. Good for you! I'd rather have a car that has 123,000 on the odo, but was warm, dry, and driven every year for 42 years. That is much better than a car driven 23k in 3 years, and then stored outside for 40 years in the rain. What's the history on that 75 garage find with 23k? |
| Mikey914 |
Mar 10 2016, 01:20 AM
Get some paint shot in there before you put it all back together. You can always re do it later, but it's not that hard to do in an engine compartment. |
| Matty900 |
Mar 26 2016, 07:15 PM
Coming and going. Got the 72 home to complete the body work and prep for paint. Lucas has been busy this week with with the DA sander, stud welder and dent puller.
Sent the wide body out to fix the wheel spacer issue and bent trailing arm. May be able to get both cars to West Coast Rally Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:12 AM |
