32 Pages V < 1 2 3 4 5 > »
> BUILD-OFF CHALLENGE: Barn find with 50k original miles
veekry9
post Feb 10 2016, 04:25 AM
Post #41
OldMember
Group: Retired Members
https://www.youtube.com/watch?v=3O-Ol2OmZxg
In your neck of the woods,a good choice in a one stop shopping trip is the Eastwood line of products.
Rust prepping,
rust neutralizing,
more prepping,
masking.
epoxy primer,
sanding,
masking,
more primer,
sanding,
masking,
color dusting,
color coating,
sanding,
buffing,
polishing,
gleaming.
A lot of work,you have to be prepared to be diligent in the details.
It's the why of automotive body and painting costs,a lot of work.
http://www.eastwood.com/paints/2k-aero-spray-paints.html
https://www.google.ca/webhp?sourceid=chrome...t+supply+oregon
Did I mention sanding?
First.
Try out your skills on a old rusted fender,2 square yards.
If you can,with the labor you supply,bring it back to a finish that everyone says is beautiful,why then proceed with the 914.
Mikey914
post Feb 10 2016, 09:32 AM
Post #42
The rubber man
Told him to try cleaning with simple green 1st. There is a steam cleaner so that will help. See what you have before you make too many plans. It may mostly clean up nice, but I'm thinking the about of work needed is minimal . It looked pretty solid.
Dave_Darling
post Feb 10 2016, 06:13 PM
Post #43
914 Idiot
QUOTE(Matty900 @ Feb 7 2016, 12:14 PM) *
So I need to expect that at some point I will need to have some engine work. Does the engine grenade or will that case be reusable? Just replace the heads?
If you're talking about the failure mode from thin barrels, then I would guess that the most likely one is that you start getting combustion gases blowing out around the seal there, burning away part of the head and part of the cylinder. Unlikely to affect the bottom end, but sometimes stuff does happen.
--DD
Matty900
post Feb 11 2016, 01:44 AM
Post #44
I was able to get a better look at the car today. It really is pretty solid. I did get some better pictures of it and in looking at the hell hole, I can see that the rust has go all the way through the metal in some pin holes.
Matty900
post Feb 11 2016, 01:48 AM
Post #45
I am not sure what rust issues I may have inside the longs.hopefully it is not too bad under the rocker pannels
Matty900
post Feb 11 2016, 01:51 AM
Post #46
Took off the rocker pannels and there was lots of dirt. (Thankfully very dry dirt) the rest looks great
Matty900
post Feb 11 2016, 10:14 PM
Post #47
What is the best way to take care of this level of rust in the hell hole? Who do you prefer to get the metal from, or do you just make your own patch for this?
Matty900
post Feb 18 2016, 12:57 AM
Post #48
Decided to go ahead and fix the damaged fender and minor dings aroundthe body and paint the car. So I guess this is project thread now.
Matty900
post Feb 18 2016, 01:01 AM
Post #49
Everything is coming apart nicely.
Matty900
post Feb 18 2016, 01:08 AM
Post #50
Getting ready to steam clean everything.
Matty900
post Feb 18 2016, 01:17 AM
Post #51
Very nice red breaks. I guess there was some leftover in the can after the fender. Sent these off to Eric at PMB. Will be replacing breaks, bearings and suspension all the way around.
Now I just need to find a factory front swaybar. Anyone have one they are willing to part with?
Matty900
post Feb 18 2016, 04:51 PM
Post #52
Steam cleaning today
Matty900
post Feb 18 2016, 10:47 PM
Post #53
Few more photos from today
Krieger
post Feb 19 2016, 12:04 AM
Post #54
Nice find! Add the Vin to our data base.
Matty900
post Mar 8 2016, 08:41 PM
Post #55
(IMG:style_emoticons/default/piratenanner.gif) Hell hole fixed!
cwpeden
post Mar 8 2016, 10:26 PM
Post #56
Great White North, huh?
Nice progress, looks like you have a mix of long and short wheel bolts. If you run the fuchs make sure to find a full set of long bolts.
hot_shoe914
post Mar 9 2016, 08:57 PM
Post #57
on ramp passer
QUOTE(iwanta914-6 @ Feb 4 2016, 09:37 PM) *
I'll never understand how people find these cars...
I am considering buying a 75 garage find with only 23K miles on it.
Hank914
post Mar 9 2016, 10:34 PM
Post #58
QUOTE(hot_shoe914 @ Mar 9 2016, 06:57 PM) *
Good for you!
I'd rather have a car that has 123,000 on the odo, but was warm, dry, and driven every year for 42 years. That is much better than a car driven 23k in 3 years, and then stored outside for 40 years in the rain.
What's the history on that 75 garage find with 23k?
Mikey914
post Mar 10 2016, 01:20 AM
Post #59
The rubber man
QUOTE(Matty900 @ Mar 8 2016, 06:41 PM) *
Get some paint shot in there before you put it all back together. You can always re do it later, but it's not that hard to do in an engine compartment.
Matty900
post Mar 26 2016, 07:15 PM
Post #60
Coming and going. Got the 72 home to complete the body work and prep for paint. Lucas has been busy this week with with the DA sander, stud welder and dent puller.
Sent the wide body out to fix the wheel spacer issue and bent trailing arm. May be able to get both cars to West Coast Rally
- Lo-Fi Version Time is now: 2nd April 2026 - 08:37 AM
