> Taking engine off the engine stand
Amphicar770
post Apr 28 2016, 08:00 PM
Engine is ready to come off the stand. But, um, what is best way to do so.
I originally had it (engine) sitting on Harbor Freight Lift Table. Raised it up to height of engine stand and pushed it on. Am thinking same approach to remove it. I do not have an engine hoist.
For mating the tranny should I just leave the engine on the lift table or place it on the floor? I did pick up the engine / transmission lifting plate from Tangerine Racing. I *think* that is designed to lift the engine only after it is attached to tranny and should not be used just engine alone? Is that correct? Not sure best way to get the plate and the jack under the assembled trans / engine. Just get a few big folks to help lift it?
I will have to do some additional manuevering due to my four post lift. Some of you may recall when I removed engine that the tins and engine brace are wider than the lift runners.
stugray
post Apr 28 2016, 11:39 PM
My car has after market headers so there are 4X stub tubes that I can put on while still on the stand.
With the stock exhaust I would put the exhaust on after the engine is in.
To get the engine down I just put on the engine bar and use a two man lift (one person on each side one hand on engine bar other on yoke) to pull the yoke out of the engine stand and set it on the floor on some 2X4s. Then bolt up the tranny.
then you can tip the engine up in the air by the tranny and slide the jack under it.
mein_tag
post Apr 29 2016, 03:29 AM
I use a cherry picker, and support the engine, and lift up the whole assembly. Separate the stand from yoke, and lower it down.
Pelican -6 methods
Krieger
post Apr 29 2016, 10:30 AM
I pulled my engine and trans for my 6 using the harbor freight lift table. I then pulled the trans off the engine and lifted the table with the engine on it and mounted it to the stand. You can pick up and manuever the stand around the table/engine. I plan on putting it back in the same way. I have the smaller of the two lift tables
post Apr 29 2016, 10:46 AM
914-6 GT in waiting
We use 1000lb lift tables all the time
- Lo-Fi Version Time is now: 2nd April 2026 - 12:19 PM
