| 914forme |
Apr 22 2016, 10:01 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
King starboard, you can staple to it, easily machined, use it a lot in my boat restorations.
Can be heavy, but works very well |
| Mikey914 |
Apr 23 2016, 12:38 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Looks like we will have a resolution this next week.
| Mikey914 |
Apr 29 2016, 01:47 AM
Well we have some resolution on this. It will NOT be fiberglass.
We will make them with 2 options, identical to OEM, and another in plastic. The plastic will be a little more, but will not have the problems the fiberboard does. We plan to have the 1st sets /sets at WCR. At least that's our goal. So sign up now ! |
| 914_teener |
Apr 29 2016, 06:56 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Well we have some resolution on this. It will NOT be fiberglass. We will make them with 2 options, identical to OEM, and another in plastic. The plastic will be a little more, but will not have the problems the fiberboard does. We plan to have the 1st sets /sets at WCR. At least that's our goal. So sign up now ! Do we still sign up here Mark or the website? I.m still in for one set. |
| Mikey914 |
Apr 29 2016, 11:16 AM
Just as soon as I can get a production estimate (in the next week or so) I will start PM'ing all who have added to the thread, then we will open up the GB. I just need to have the schedule in place before I open it up.
Thanks to all,and it's not too late if you want a set. |
| ThinAir |
Apr 29 2016, 11:19 AM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
I'm interested
| 7TPorsh |
Apr 29 2016, 12:45 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
Interested in early black......if there are no plans for the RS design.....i would really like the RS design.. :-)
| Mikey914 |
Apr 29 2016, 03:44 PM
RS design can be sewn, would be an adder but yeah can be an option.
| mapguy |
Apr 29 2016, 04:53 PM
Freelance Generalist ![]() ![]() Group: Members Posts: 98 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
Interested in late tan (for a '74)
| RoadGlue |
Apr 29 2016, 05:16 PM
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,034 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California
You know me Mark - I'm down for a late set for a '74 as well. I'm sure either construction option is fine. PM when you're ready!
| napasteve |
Apr 29 2016, 05:44 PM
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 518 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California
I'm still in for a late set in black when they are available.
| jonferns |
Apr 30 2016, 06:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
In for a set of early ones, black. Thanks
| Dave_Darling |
Apr 30 2016, 09:55 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
In for a pair, please! 74 (early-ish) in black.
--DD |
| Texasteener |
May 10 2016, 08:42 PM
Newbie ![]() Group: Members Posts: 7 Joined: 30-December 14 From: United States Member No.: 18,264 Region Association: Southwest Region |
Put me in for a set of '74 style tan cards!
| Heeltoe914 |
May 10 2016, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
2 sets 70 914 6 very stock
| catsltd |
May 11 2016, 06:55 AM
Member ![]() ![]() Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
1974 Black.I really only need a passenger door,but will take 2 if I must.
Thanks Grant |
| 7TPorsh |
May 18 2016, 01:01 PM
| Mikey914 |
May 18 2016, 04:26 PM
Interested in early black......if there are no plans for the RS design.....i would really like the RS design.. :-) RS design with smooth vinyl would be my 1st choice...i like mine now but can't stand these speaker cutouts and the driver's side card is broken... Naked and waiting... [size=4]Just a heads up, I don't own the rights to the artwork so.... you might want to hold off on that.. |
| Mikey914 |
Jun 5 2016, 06:42 PM
We have finally got the process selected and are proceeding to the tooling phase for the door panel GB. It's taken longer than we wanted as we originally hoped to work this out with our fiberglass provider. Unfortunately this did not work out, and we have committed to the tooling to make these out of a just as durable ABS plastic that can withstand the water, and make an OEM looking panel. We have added the nut plate that was not previously on the fiberglass ones. We also include all 3 upper mounting tabs attached to allow you to pop them right in.
We are in the pre-buy phase. What this means is that they can take 4-6 weeks before you have in hand, but you lock in your cost. If the costs go up, and they may a little, you are buying at the lower cost just like we did with the dashes. So if you plan to replace your door panels now's the time. These are sold without the door clips in them, but we have available if you need them. You can reuse yours or we can sell you more. Thanks for your support, so we can make these parts more reasonably. You can find these here - http://www.shop.914rubber.com/Door-pannel-...der-914DPGB.htm As far as RS panels we have added the option. Thanks to all for your patience, these are finally moving forward. |
| Mikey914 |
Jun 5 2016, 06:43 PM
PMs sent to all that inquired
Lo-Fi Version | Time is now: 2nd April 2026 - 08:55 AM |
