| rgalla9146 |
May 18 2016, 05:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Anyone here have experience with self contained 12V AC compressor ?
Mounts remote from engine, driven by electric motor. Seems it might be a way to have AC on a 6 conversion. Jegs sells them in two capacities. Pretty spendy. |
| whitetwinturbo |
May 18 2016, 06:12 PM
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
| bandjoey |
May 18 2016, 06:40 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about.
http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ |
| rgalla9146 |
May 18 2016, 07:53 PM
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about. http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ As mentioned, sold by Jegs part # 51810 9 -30 volts, 31 amps, 3753 btu Available in two versions for small or larger cars. (specs listed are for the smaller unit) Was $1199 ...... now $749.99 Not doable with a 160 amp 911 alternator ? Has anyone here seen one installed on anything ? |
| Gunn1 |
May 18 2016, 08:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
[quote name='rgalla9146' date='May 18 2016, 08:53 PM' post='2346865']
[quote name='bandjoey' post='2346821' date='May 18 2016, 08:40 PM'] Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about. http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ [/quote] As mentioned, sold by Jegs part # 51810 9 -30 volts, 31 amps, 3753 btu Available in two versions for small or larger cars. (specs listed are for the smaller unit) Was $1199 ...... now $749.99 Not doable with a 160 amp 911 alternator ? Has anyone here seen one installed on anything ? Prob need a higher output alternator or maybe a dedicated alternator that would run just the AC, would probably still be easier than installing an old school set up |
| barrym |
May 18 2016, 08:04 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
A few of my lotus friends have used this solution with engine swaps where it's hard to mount a compressor in limited space.
Yes, you need a correctly sized alternator, but the platform works just as advertised, but I wouldn't be looking at this for any cabin size larger than an Elise / 914 |
| Gunn1 |
May 18 2016, 08:19 PM
A few of my lotus friends have used this solution with engine swaps where it's hard to mount a compressor in limited space. Yes, you need a correctly sized alternator, but the platform works just as advertised, but I wouldn't be looking at this for any cabin size larger than an Elise / 914 I got it ....fill the Frunck with ice cubes and redirect the fresh air intake into the Frunck. Make sure to set up some sort of drain though. |
| r_towle |
May 18 2016, 09:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Boating world has made some great progress in sure small heat/AC units running off 12 Vdc.
Those are sized to service large cabins maybe ten time the size of a 914 cabin. From what I have read, these are just how it's done now. Taking that design and scaling it down...I don't see any reason why it would not work fine....just need to see the power requirements. Heating and cooling with electricity is not magic, it takes power to make heat and cooling... |
| boxsterfan |
May 18 2016, 10:20 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I think McMark fitted a 130A GM alternator on a type IV motor with or without built-in voltage regulator. There is also a 230A GM alternator that can be used just as the 130A one.
| Gunn1 |
May 19 2016, 12:17 PM
Boating world has made some great progress in sure small heat/AC units running off 12 Vdc. Those are sized to service large cabins maybe ten time the size of a 914 cabin. From what I have read, these are just how it's done now. Taking that design and scaling it down...I don't see any reason why it would not work fine....just need to see the power requirements. Heating and cooling with electricity is not magic, it takes power to make heat and cooling... That being said, when you increase the output of the alternator don't you increase the power consumed to spin it? I would be curious to know which set up was more efficient. In other words the power needed or used to produce the same BTU's |
| jd74914 |
May 19 2016, 01:02 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about. http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ As mentioned, sold by Jegs part # 51810 9 -30 volts, 31 amps, 3753 btu Available in two versions for small or larger cars. (specs listed are for the smaller unit) Was $1199 ...... now $749.99 Not doable with a 160 amp 911 alternator ? Has anyone here seen one installed on anything ? I don't see why you couldn't use one with the 160A alternator; I would assume that your car draws nothing near that load (assuming you're not rocking a xrazy stereo, etc.). |
| Dave_Darling |
May 19 2016, 01:49 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
In other words the power needed or used to produce the same BTU's Converting energy from one form to another is never 100% efficient. The more conversions you have, the worse the efficiency is. With one setup, you have mechanical energy -> thermal energy. With the other, you have mechanical energy -> electrical energy -> mechanical energy -> thermal energy. The first one needs to be hellaciously inefficient, and the latter three all very efficient, for the second setup to be more efficient than the first. Given the same type of mechanical compressor at the end, the electric-driven one will never be as efficient as the straight mechanical one. --DD |
| jeffdon |
May 19 2016, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
A few of my lotus friends have used this solution with engine swaps where it's hard to mount a compressor in limited space. Yes, you need a correctly sized alternator, but the platform works just as advertised, but I wouldn't be looking at this for any cabin size larger than an Elise / 914 I got it ....fill the Frunck with ice cubes and redirect the fresh air intake into the Frunck. Make sure to set up some sort of drain though. I believe Eliot did an ice based AC system using an ice chest, coil in the ice, water in the coil, all pumped through a heater core with a fan. I seem to recall him saying it worked pretty well even in the hot summers he gets. Just need to replenish the ice once in a while. Bet with some of the new super ice boxes, like Yeti, and with a brine/ice solution, it would be even better. |
| porschetub |
May 19 2016, 06:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
230amp altenator holy...drive that ,turn the cooling fan and turn the back wheels,might need a BIG Raby motor for that system (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) .
Not to mention a suitable battery and associated wiring to power the beast. I lived in Australia pretty hot there , I wound down the window (IMG:style_emoticons/default/dry.gif) |
| Steve |
Aug 5 2016, 12:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I am starting to see this one pop up in various threads.
Benling DM18A7 From Chine it lists for $300.00 on eBay they want $899 for it. It looks pretty promising, but no luck finding one. http://m.made-in-china.com/product/Dm18A7-...-761066265.html https://m.alibaba.com/product/60112520554/1...sor-DM18A7.html |
| jim_hoyland |
Aug 5 2016, 05:49 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Steve: what's your alternator put out ? How many amps will the electric compressor require ?
| Steve |
Aug 5 2016, 05:57 PM
| Elliot Cannon |
Aug 5 2016, 08:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
A few of my lotus friends have used this solution with engine swaps where it's hard to mount a compressor in limited space. Yes, you need a correctly sized alternator, but the platform works just as advertised, but I wouldn't be looking at this for any cabin size larger than an Elise / 914 I got it ....fill the Frunck with ice cubes and redirect the fresh air intake into the Frunck. Make sure to set up some sort of drain though. I believe Eliot did an ice based AC system using an ice chest, coil in the ice, water in the coil, all pumped through a heater core with a fan. I seem to recall him saying it worked pretty well even in the hot summers he gets. Just need to replenish the ice once in a while. Bet with some of the new super ice boxes, like Yeti, and with a brine/ice solution, it would be even better. I worked at it for awhile. Kinda gave up on it. These work well. I would guess it would last about 2 hours or so before you have to stop for more ice. In an airplane you might only need it for a short while anyway. It can get pretty cool at altitude. http://portable-aircraft-air-conditioners-...nstruction.com/ |
| Series9 |
Aug 5 2016, 08:29 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The answer is: NO.
I don't feel like explaining it right now, but forget about it. |
| Rand |
Aug 5 2016, 09:17 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
It would work about as well as a 12v electric heater. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 11:23 AM |
