| Keith914 |
Sep 23 2016, 10:21 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
To the "brain trust". Two experienced engineer/mechanics have described the following:
When our Type IV engines are at operating temperature and rpm's exceed about 3,000 the pressure relief valve (ball bearing valve seen in the oil filter bracket) opens up and prevents or reduces oil flow through the filter. Thus, this reduces oil flow through external oil coolers attached via a "pancake" to the engine, greatly reducing there cooling effect when needed most, e.g. at the track. They have altered this valve so that it cannot open, and advised to keep rpm's low until the engine is warmed up -- particularly in cold climates. there are various ways to "plug" this valve, easy when removed from the engine, -- drill and thread a bolt with lock nut to hold the ball bearing closed, press in an aluminum plug, etc. Two questions: 1) are there other (than too high an oil pressure with cold engine with higher rpm's) unintended consequences, and 2) can this valve be "plugged" and how, without removing the engine to get at it? |
| ChrisFoley |
Sep 23 2016, 10:48 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
AFAIK, the only downside to disabling the bypass valve occurs if your oil filter becomes clogged somehow.
At that point you will have no oil pressure and will cook the bearings right away. Personally, I would prefer to increase the cracking pressure of the bypass valve rather than completely disable it. But I haven't devised a method yet. |
| Elliot Cannon |
Sep 23 2016, 12:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Doesn't that valve open by oil pressure depressing a spring? Would a stronger spring help?
| N_Jay |
Sep 23 2016, 12:20 PM
Member ![]() ![]() Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Yes there are heavier springs.
You can go up until you risk popping the oil filter (or cooler). If you are generating so much heat at high RPM (high oil flow, high airflow) and still have a problem cooling, you either need a bigger cooler, thinner oil, or a dry sump system. (IMHO) |
| ChrisFoley |
Sep 23 2016, 01:19 PM
| ChrisFoley |
Sep 23 2016, 01:23 PM
| N_Jay |
Sep 23 2016, 01:27 PM
Doesn't that valve open by oil pressure depressing a spring? Would a stronger spring help? It isn't designed to be a user serviceable item. Therefore, changing the spring is complicated. Am I miss-remembering, or doesn't the spring and ball on in through a easy to access threaded plug on the bottom of the engine. And didn't some vendor (in the 80's at least) have upgraded springs? EDIT: http://www.ephotomotion.com/914engine/page08.html It is a piston valve not a ball valve. |
| ChrisFoley |
Sep 23 2016, 01:44 PM
Keith called it a relief valve, but he described the bypass valve.
The pressure relief valve is located in the location you described. |
| TheCabinetmaker |
Sep 23 2016, 01:48 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Njay they are referring to the filter bypass ball in the oil filter console. The op obviously misstated "relief" valve.
| N_Jay |
Sep 23 2016, 02:00 PM
| ChrisFoley |
Sep 23 2016, 02:53 PM
a couple psi
| Keith914 |
Sep 23 2016, 04:53 PM
I am referring to the valve that has a ball bearing looking "thingy" one can see when the filter is removed.
| stugray |
Sep 23 2016, 06:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I ran my racecar for a whole season with a sandwich adapter to my oil cooler with the bypass valve in stock form.
I didnt have any trouble keeping the car cool. (I DID get pissed however when I dumped about $40 worth of brand new Brad Penn on the floor of my garage by getting the o-ring pinched during a routine oil change) One secret is to make the lines to the OC as large as possible to reduce pressure drop across the OC loop. I used 12 AN to the front & back. I have since changed to the OC adapter plate mod instead of the sandwich adapter. (anyone need a sandwich adapter with 12AN fittings?) |
| barefoot |
Sep 24 2016, 04:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Njay they are referring to the filter bypass ball in the oil filter console. The op obviously misstated "relief" valve. Haven't started my 2056 build yet, so i looked closely at the pressed in ball seat in the oil filter console & noted that it was somewhat cocked and not pressed in fully. The ball had very little preload from the spring. I pressed the ball seat down flush and it seemed that the spring preload was now greater. Pull your filter console off and inspect that ball seat ! |
| stugray |
Sep 24 2016, 06:59 AM
This is the focus of the OP I believe:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1474721992.1.jpg) I considered drilling & tapping the hole for a plug. Since I run a K&P oil filter, & clean it frequently I didnt see it ever getting clogged enough to trigger that valve. But if you have a OC loop in between the bracket and the filter and the oil is really cold and the oil doesnt want to flow towards the oil cooler (yet) I thought leaving the ball valve stock was sort of a thermostat. This might help: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1474722504.1.jpg) |
| Keith914 |
Sep 24 2016, 12:40 PM
Thanks for the input and flow diagrams.
It is clear from the flow diagrams that the filter relief valve has the ability to reduce the flow to an outside in series filter and cooler that is connected directly to the stock oil filter console. This confirms the explains the experienced advice. Unfortunately it is also clear that while there are several ways to eliminate this by pass valve function, they require removing the engine to either; 1) access the upper oil filter console nut to remove the console for modification, or 2) to connect the external filter/cooler system to the galley plugs next to the oil pump. |
| jim_hoyland |
Nov 3 2016, 02:20 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Question: does the oil filter relief valve in effect reduce the flow or pressure to the cooler ?
| stugray |
Nov 3 2016, 02:26 PM
| jim_hoyland |
Nov 3 2016, 04:18 PM
Question: does the oil filter relief valve in effect reduce the flow or pressure to the cooler ? ONLY if you are using an oil cooler plumbed via a sandwich adapter from the filter bracket. Mine will fall into that category; should I plug the filter relief valve ? Bring in So Cal where it doesn't get very cold; good ? |
| yeahmag |
Nov 3 2016, 05:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I've taken to pulling them out and TIGing in a plug. I'll let the oil filter do the bypassing if it needs to...
Lo-Fi Version | Time is now: 2nd April 2026 - 04:34 AM |
