| wayner |
Sep 30 2016, 06:47 AM
Newbie ![]() Group: Members Posts: 45 Joined: 25-July 16 From: Canada Member No.: 20,223 Region Association: None |
Aside from the nose of the car, where else do,people mount oil coolers?
Is there a second popular alternative setup? |
| barefoot |
Sep 30 2016, 07:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Bump it up to a 2056 along with the head work and exhaust. 2056 P&C set: http://www.ebay.com/itm/251635106531?_trks...K%3AMEBIDX%3AIT |
| Dave_Darling |
Sep 30 2016, 01:56 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Aside from the nose of the car, where else do,people mount oil coolers? Is there a second popular alternative setup? The next most popular locations seem to be on the engine lid, or under the rear trunk floor. The engine lid location keeps your lines short, which is a positive. The cooler can also get a little air flow from the engine cooling fan, drawing air into the engine bay. The downsides are that the cooler is above the engine, which can make oil changes more "interesting", and that you pre-heat a bit of your cooling air and intake air. Also the cooler will live in a moderately-warm environment, reducing its effectiveness somewhat. Rich at HPH in Redwood City has recommended this type of setup in the past. The location under the trunk floor keeps everything out of the way. Plus the cooler is pretty close to the same level as the engine sump, meaning you don't have oil moving one way or the other on its own. But under the trunk floor tends to be a very warm environment, with not much air flow. This makes the cooler much less effective. You can combat that to some extent by making the cooler larger, and putting a fan on it, but there's only so much that can be done. The front mounted cooler is the best location as far as cooling goes. It does have some downsides, including long (more costly) lines, the need to cut holes for the lines, the requirement for ducting to get air in and out of the cooler, and so on. But for cooling, it is absolutely the best. The cooler in my car is under the rear trunk floor. --DD |
| wayner |
Sep 30 2016, 04:47 PM
Great insite. Thanks!
| Chris Pincetich |
Sep 30 2016, 06:01 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Header and light flywheel feel great! (IMG:style_emoticons/default/driving.gif)
I made a custom intake to get colder air from up by the relay board, and we all know cold-air intakes are good for +0.005 HP! Or more...(IMG:style_emoticons/default/beerchug.gif) I always say a header is the best bolt-on upgrade, but that's because I don't have McMark's turbo+FI (IMG:style_emoticons/default/biggrin.gif) |
| wayner |
Oct 16 2016, 08:04 AM
I've been thinking. If my 2.is as solid as I think, rather than a small bump from2000 to 2056, what if I go all out on heads and cam, keeping my cylinders and/or pistons
What's the recipe? |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:57 AM |
