> SOT: Drill bits, and abrasives for metal, What are the best
jeffdon
post May 3 2017, 09:28 PM
I have kinda had it with the locally available bits and abrasives. Doing a lot of drilling in hot rolled steel, and am slated to have to do tons more. There has got to be something better than the Irwin brand cobalt bits for this.
Found this site: http://www.wintersdrillbitcity.com/
It does not have a much info in the way of prices, etc. Rather old school.
Anyone have any experience with these guys? Or any suggestions? I am so done buying drill sets, and would just like to buy the bits I tend to use by the dozen or more.
Also, been doing some finishing on steel flat bar that needs to be glass smooth. Been having good results with a belt sander running the black gator brand belts, but like the drill bits, wonder if there might be something better.
Fabricators, chime in!
cary
post May 3 2017, 10:28 PM
My choice in drill bits is Norsemen/Viking.
http://www.albanycountyfasteners.com/Norse...=1&CartID=0
I've never used these guys. I usually buy from EMI but they seem to be having website issues.
jd74914
post May 3 2017, 10:38 PM
Its alive
Best abrasives are from Lehigh Valley Abrasives. (IMG:style_emoticons/default/smile.gif)
PlantMan
post May 3 2017, 10:41 PM
Stick with USA or European bits from a quality high grade tool steel.
Try to find a metal supply shop or tool supplier that sells machinist tools. I have purchased from these shops before with great results.
I am sure there are many businesses in your area that can help you out.
Good luck.
jeffdon
post May 3 2017, 11:17 PM
All awesome info. Thanks, All!
saigon71
post May 4 2017, 05:43 AM
During my restoration, I had excellent results with this type of drill bits from Lowes. They last a very long time:
https://www.lowes.com/pd/DEWALT-14-Pack-Gol...it-Set/50035424
For sanding & grinding, I buy in bulk from Keen Abrasives:
http://www.keenabrasives.com/
TheCabinetmaker
post May 4 2017, 05:59 AM
I drive my car everyday
Mirka gold. Best abrasives available in my opinion.
McMark
post May 4 2017, 06:08 AM
914 Freak!
Get yourself a Drill Doctor too. You can resharpen cobalt bits. But, HSS and Titanium bits are coated, so resharpening doesn't work since the metal inside isn't hardened.
I've gotten in the habit of sharpening a but every time the cutting starts to slow. You can sharped them in under 1min and they work like new.
no1uno
post May 4 2017, 06:51 AM
+1 to Norseman. Use their T190-AG bits. 135* split point. Easy to find at any Fastenal location. Fastenal has many locations all over the country
6freak
post May 4 2017, 06:56 AM
MR.C
you on a press or just a drill motor,speed kills most bits! try slowing down the speed of the drill ..good luck
post May 4 2017, 08:08 AM
(IMG:style_emoticons/default/agree.gif) Low speed, lubrication and knowing when the bit is cutting. Once it begins to cut the proper feed pressure will keep it cutting. If you stand on the bit and it isn't cutting i.e. just spinning, then you harden the metal your trying to drill. Takes practice!
I've always enjoyed the American made cobalt bits supplied by Avery Tools. (IMG:style_emoticons/default/beerchug.gif)
mbseto
post May 4 2017, 02:30 PM
QUOTE(76-914 @ May 4 2017, 10:08 AM) *
QfT
Mueller
post May 4 2017, 03:29 PM
914 Freak!
If cutting metal I'd ditch the abrasive saw....I just picked one of these saws last weekend (wife bought it for me, no idea on cost, but it is nice)
https://www.youtube.com/watch?v=5hUJclLEwZc
Elliot Cannon
post May 4 2017, 10:53 PM
Group: Retired Members
Get rid of the abrasive blade. Go to dry cut blade. The difference is amazing. Everything is easier with a drill press. I will use a drill bit in my drill press that works so much better than with my hand held drill motor.
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 AM
