| JHop |
Sep 16 2017, 09:26 AM
Newbie ![]() Group: Members Posts: 28 Joined: 18-February 16 From: Portland, OR Member No.: 19,685 Region Association: Pacific Northwest |
Hey guys,
My teener needed to have the old '80s under dash stereo taken out, the PO had it set up with switches...those are now gone. Question 1: which wire out of the ignition switch goes to the radio (switched hot with the ignition.) Question 2: Passenger side lights are all out (headlight, running lights, tail light). Drivers side works fine. Checked fuses, all appear good. Where else do I need to look? Any ideas? Thanks in advance. Trying to get the last bits sorted before she sells. John |
| euro911 |
Sep 16 2017, 09:54 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
The wiring diagram(s) don't show the radio power, but check your headlight relays and ground connections for that issue.
Click on the appropriate year for a wiring diagram for your car ... http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
| raynekat |
Sep 16 2017, 06:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
I wouldn't think the radio power would come directly from the ignition switch. It will come off the fuse panel. My wiring diagram doesn't show where a radio would be hooked up per se.... But it makes sense it would when the key was in the run position in the ignition switch. AKA the run circuit. On my wiring diagram, that is fuse position #8 in the fuse panel. Brakes, wipers, lights, etc are all coming off this #8 fuse. So that is where I would begin looking for your radio power. Fuses can "look" fine but many times are not. When in doubt, just replace all with new fuses. They're not all that expensive. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:44 AM |
