| 914 |
May 3 2016, 08:17 AM
Senior Member ![]() ![]() Group: Members Posts: 468 Joined: 26-December 02 Member No.: 19 Region Association: Southern California
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914 |
914 914-4 Battery? May 3 2016, 08:17 AM
Amphicar770 A lot of people use the Optima batteries. No worr... May 3 2016, 08:49 AM
malcolm2
A lot of people use the Optima batteries. No wor... May 3 2016, 09:11 AM
era vulgaris
[quote name='Amphicar770' post='2339580' date='Ma... May 3 2016, 06:21 PM
1TRICK6 Bosch 96R battery fits perfect.
Check PepBoys, usu... May 3 2016, 09:13 AM
malcolm2 Something else I really like are my connectors. I... May 3 2016, 09:22 AM
914 Thanks everyone for the reply's.I got the Bosc... May 3 2016, 06:10 PM
porsche913b_sp
Thanks everyone for the reply's.I got the Bos... May 3 2016, 08:16 PM
struckn If it's a Vented Battery, such as I have, buy ... May 4 2016, 07:42 AM
Drums66
If it's a Vented Battery, such as I have, buy... Oct 10 2017, 01:41 PM
championgt1
Thanks everyone for the reply's.I got the Bo... May 5 2016, 09:25 AM
914 Here is the Bosch battery..Again Thanks everyone f... May 4 2016, 05:35 PM
Amphicar770
Here is the Bosch battery..Again Thanks everyone ... May 5 2016, 08:24 AM
914 Always used a mat on my Four and Six..
914 May 5 2016, 08:59 AM
JFG Any chance you can post the dimendions of the bosc... May 23 2016, 03:22 AM
dlkawashima The battery purchased by the original poster is a ... May 23 2016, 04:32 AM
1stworks Here's what I did.
http://www.914world.com/b... May 23 2016, 06:59 AM
Cairo94507 When it comes time for a battery, it is going to b... May 23 2016, 08:21 AM
dlkawashima
When it comes time for a battery, it is going to ... May 23 2016, 09:53 AM
fslick dlkawashima, do you run a size 34? Would really li... Oct 9 2017, 01:58 PM
Philip W.
[quote name='Cairo94507' post='2349034' date='May... Oct 10 2017, 07:38 AM
fslick Dr. Phil -- if you do order the Bosch AGM from pep... Oct 10 2017, 11:52 AM
Philip W.
Dr. Phil -- if you do order the Bosch AGM from pe... Oct 10 2017, 11:56 AM
arne I put a Miata U1R AGM in mine. Smaller, lighter, c... Oct 9 2017, 04:22 PM
fslick Cool! I think next go around I'll do AGM. ... Oct 9 2017, 09:03 PM
ThreeV8s
I put a Miata U1R AGM in mine. Smaller, lighter, ... Nov 3 2017, 05:34 PM
ThreeV8s
I put a Miata U1R AGM in mine. Smaller, lighter,... Nov 6 2017, 09:16 AM
Coondog RE: 914-4 Battery? Oct 9 2017, 10:06 PM
Rand It's a no-brainer to avoid lead-acid. :sick: T... Oct 9 2017, 10:48 PM
gereed75 It is pretty common in the experimental aircraft w... Oct 10 2017, 07:25 AM
arne
It is pretty common in the experimental aircraft ... Oct 10 2017, 11:55 AM
malcolm2
It is pretty common in the experimental aircraft... Oct 11 2017, 08:44 AM
mzalanka
[quote name='arne' post='2536236' date='Oct 10 20... Oct 12 2017, 10:09 PM
porschetub
It is pretty common in the experimental aircraft ... Oct 10 2017, 03:27 PM
ValcoOscar Another option:
25% Off Online Orders of Select H... Oct 11 2017, 08:52 AM
ThreeV8s
Another option:
25% Off Online Orders of Select ... Oct 12 2017, 07:24 PM
ThreeV8s Can anyone confirm if this "non-spillable... Oct 29 2017, 05:02 AM
Elliot Cannon I just found this tonight. http://www.batterymart... Nov 6 2017, 10:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:32 AM |
