| RickS |
Dec 31 2017, 06:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better.
| ConeDodger |
Dec 31 2017, 06:40 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Mine has been both a 4 and a 6 with the Rennshift And shift rod And McMark mod. Attached thumbnail(s) |
| Steve |
Dec 31 2017, 07:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. |
| RickS |
Dec 31 2017, 07:50 PM
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. Can’t find any mention on the JWest site of 915 conversion parts or a kit. I do see the 914 side shift shifter. Do not see a straight shift rod being offered. Hmmm . Still not clear on what the McMark mod is. |
| Steve |
Dec 31 2017, 08:02 PM
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. The shift rod has a bend so you are saying it has to be straight and that and the conversion parts are Sold by JWest. Excellent. Will go check the JWest site. Hope that is all the conversion pieces. Still not clear on what the McMark mod is. JWest sells two Rennshift models 914-4 side shift 914-4 tail shift and 915 gear box. I originally had my 914-4 shift rod straightened when I did my six. Later I converted to a PMS shift rod for my six. I don’t think JWest sells six conversion shift rods anymore, but PMS and CFR (Tangerine Racing) does. http://www.patrickmotorsports.com/part/914...smissions-only/ |
| RickS |
Dec 31 2017, 10:54 PM
Thanks Steve for all the help. Parts ordered. Much appreciated and Happy New Year
| maf914 |
Jan 1 2018, 01:26 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
I’ve got the whole Rennshift package from the shifter to the transmission + the McMark modification. I think I know what the Rennshift (Jwest) package is, and also the Tangerine linkage kit, but I am not familiar with the McMark modification. Could someone describe this and maybe post a picture? Thanks. |
| PlaysWithCars |
Jan 1 2018, 01:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 541 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest
I installed a Rennshift earlier this year. It was an improvement, but wasn’t as dramatic as I hoped. But I’ve felt others and they were superb. Perhaps I need some more adjustment?
Regarding the slot for a hand throttle? It wasn’t hard at all to cut one into the baseplate and install the hand throttle per usual. Mine works great. I also used the Wevo knob, but I elected for the one that slips on with a crush sleeve. |
| VaccaRabite |
Jan 1 2018, 08:02 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-1435-1514858545.1.jpg)
Yeah, worth every penny. Zach |
| 914forme |
Jan 2 2018, 11:48 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
I'm not sure I want to sacrifice my hand throttle mechanism..... I've seen people jury rig them. I'd have to be convinced this is a huge step forward. 914forme modded his rennshift for the hand throttle Here is a link to the thread showing 914forme's Rennshift modification for a hand throttle. See post #213. Here is the photo: That is similar to what I was thinking. Have to look closely at how the space for the throttle handle baseplate is accommodated under the shifter base plate. Also, possibility of mounting the hand throttle assembly say 2' in front of the shifter base plate on the tunnel by drilling holes for bolts and cutting slot for handle and shortening the rod the same amount (?) To easy to do and no other modifications needed. Also gave me a good reason to make some chips fly. If you don't have access to a mill, it can be done with hand tools. Drill a hole out back big enough for the post to run up through, and then just cut two down the center. It is strong enough that flex should not become an issue with the minimal removal for the handle to move. You also have to drill one hole for the nub oil the hand throttle mount to key into. |
| RickS |
Jan 13 2018, 12:20 AM
Installed the Rennshifter and what a fantastic difference. After lots of trial and error, error meaning losing reverse and first, it is 95% dialed in. It is so precise and takes the guesswork out of Gear changes. Very solid and reassuring.
The final 5% is getting the shift into 2nd so solid, that there is no way to just Knick reverse. Relatedly, The main issue is the reverse lockout tends to hit the shift lever dead center and locks out first too unless I move the lever a bit back to get around it and it totally locks out reverse. The solution was to remove it unless someone knows a trick. Don’t need the Patrick Motorsport stuff since I already have a bronze bushing in the firewall, a straight rear shift rod with a ball coupler. The steering coupler seems redundant so it is all going back. If this was a new conversion to a 6 it would have been helpful. |
| gothspeed |
Jan 13 2018, 11:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Mine has been both a 4 and a 6 with the Rennshift And shift rod And McMark mod. Is that a real picture or some photoshop creation? It looks AWESOME!!! (IMG:style_emoticons/default/smilie_pokal.gif) |
| Driver174 |
Feb 3 2019, 08:09 PM
Member ![]() ![]() Group: Members Posts: 122 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None
What is this “McMark mod”?
| jdeitch |
Sep 21 2022, 08:00 PM
Newbie ![]() Group: Members Posts: 2 Joined: 27-July 22 From: Dover, PA Member No.: 26,719 Region Association: North East States |
I installed a Rennshift earlier this year. It was an improvement, but wasn’t as dramatic as I hoped. But I’ve felt others and they were superb. Perhaps I need some more adjustment? Regarding the slot for a hand throttle? It wasn’t hard at all to cut one into the baseplate and install the hand throttle per usual. Mine works great. I also used the Wevo knob, but I elected for the one that slips on with a crush sleeve. Beautiful setup. What pedal are those? |
| ChrisFoley |
Sep 22 2022, 04:03 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Looks like Rennline.
| Geezer914 |
Sep 22 2022, 04:35 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,260 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I have a Renn shifter installed on my 914 and never looked back. Also Installed the Tangerine Racing shift linkage and bearing. No longer hunting for gears.
| VaccaRabite |
Sep 22 2022, 11:27 AM
This is an ancient thread.
That said, the rennshift is worth it. But, you HAVE to get your bearings freshened up. Or better yet get the Tangerine shift kit (which I have). It really transforms how the 914 shifts. Very very precise. A Rennshift on a car with bad bushings will not net ANY positive effects, and could make things worse. Zach |
| Cairo94507 |
Sep 22 2022, 12:21 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I will add I had a RennShifter in my car and it shifted terribly until I had it adjusted by someone that knows what they are doing. I had taken it to a shop recommended by J West, Sport Performance in Livermore, ( I believe they may have closed) to be adjusted properly and it still shifted very tight.
When John Holleran got his hands on it, he adjusted all the linkage angles, checked bushings and adjusted the actual Rennshifter, tons better. Despite that, I removed it and replaced it with the stock shifter with a Weltmeister short shift kit with the stock 914 arm welded on it so it looks 100% stock and also has the hand throttle. Very happy with it now. If my car was more of a GT looking car, I would have kept the RennShifter in it. (IMG:style_emoticons/default/beerchug.gif) |
| mepstein |
Sep 22 2022, 12:27 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I love my renn shifter but it will only improve shifting at the shifter. Shifting precision is only as good as the weakest link. Trans, linkage, bushings , etc. a Rennshift won’t fix a worn out trans.
Lo-Fi Version | Time is now: 2nd April 2026 - 02:57 PM |
