| advman89 |
Jul 23 2019, 08:29 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest
| 76-914 |
Jul 23 2019, 08:31 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
grounds from the DJet system.
| advman89 |
Jul 23 2019, 08:41 PM
| jcd914 |
Jul 23 2019, 10:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You don't really show much of the engine/intake/fuel injection system.
The control unit you show and the harness at the relay panel is D-jet. Is the connector in your first picture part of the FI harness going to the control unit¿ Jim |
| advman89 |
Jul 24 2019, 06:59 AM
| sixnotfour |
Jul 24 2019, 07:04 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| JeffBowlsby |
Jul 24 2019, 08:18 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Maybe. But that 6 pole connector housing should’ve near to the ECU, not the engine grounds under the air filter box |
| sixnotfour |
Jul 24 2019, 09:31 AM
QUOTE Found this mess stuffed back in a corner of the engine bay (top of the motor, under the airbox-ish, passenger side). "airbox-ish" (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/shades.gif) Attached image(s)
| advman89 |
Jul 24 2019, 11:41 AM
There is a connection stuffed under the battery-ish that probably plugged into a box similar...but that was also disconnected and stuffed there (from my poking around there last night, I remember seeing the other side of the connector there).
The engine was swapped and maybe some bodgey stuff was done...that's what I'm trying to sort out. The car does run, but it's not what I'd consider to be running at top form. |
| sixnotfour |
Jul 25 2019, 12:13 PM
the un plugged box affects nothing except emissions....
Lo-Fi Version | Time is now: 2nd April 2026 - 08:32 AM |
