| maf914 |
Dec 19 2019, 07:16 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Very nice looking work!
Make sure the O-rings are brake fluid proof. (IMG:style_emoticons/default/idea.gif) |
| Mikey914 |
Dec 19 2019, 01:50 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Making slow progress on the front rebuild. Rebuild kit for calipers did not come with the little O-Rings that seal the 2 halves. My local hardware store has lots of miscellaneous O-rings so hopefully I can find something that works. We have a line of viton O rings we make under contract for another company we have the ability sell them as it's another industry. Let me know what you need. Mark |
| tvdinnerbythepool |
Dec 19 2019, 08:16 PM
Member ![]() ![]() Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest
Thanks @mikey914 text with specs sent
Can someone educate me on the "brake piston gauge plates"? I took a 50/50 guess as to the orientation....is there a correct up and down or I guess should it be right or left? The piston could rotate 180 and go either way...?? (I'm sure if there is a wrong way that's what I did!) |
| bbrock |
Dec 20 2019, 12:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Thanks @mikey914 text with specs sent Can someone educate me on the "brake piston gauge plates"? I took a 50/50 guess as to the orientation....is there a correct up and down or I guess should it be right or left? The piston could rotate 180 and go either way...?? (I'm sure if there is a wrong way that's what I did!) Explanation starting near the bottom of the last pic in this article: https://www.pmbperformance.com/brakehowto.html |
| rgalla9146 |
Dec 20 2019, 07:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
If doing both calipers at the same time be sure to check orientation before bolting halfs together.
| tvdinnerbythepool |
Dec 20 2019, 09:22 AM
Thanks guys, trying to wrap my mind around it.
Found this pic on a 911 forum that I think helps too ![]() |
| tvdinnerbythepool |
Dec 21 2019, 02:39 PM
| tvdinnerbythepool |
Dec 21 2019, 02:40 PM
New discs and bearings are in!
Followed Ian's video for good measure. New Bilsteins, tie rod ends, ball joints, bushings, brake master cylinder, stainless lines, pads and lovely calipers will be on next once I get the o rings from 914rubber So close to getting back on the road! Can't wait to feel the difference! |
| tvdinnerbythepool |
Jan 5 2020, 06:44 PM
This car is like the most frustrating game of Whack a Mole! Fix one problem and boom there's another. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
So, suspension, brakes, everything is in rebuilt and pretty! Today's project was to set the front ride height. I followed the procedure, Floor to Center Hub - 90 and that's the height to the center of the torsion bar. A pain in the ass going in circles but I think I finally got it pretty dialed in. The issue is: now the front is raised up to the correct height the tire strikes the front valance when I turn the wheel hardly at all. I couldn't get the car out of the driveway. I did not have the issue pre-rebuild, however, pre-rebuild the car was slammed with tons of camber. My guess is, like the many issues these have brought me, it's the wheel/tire combo. Rivieras with 195-60R15. I think they are just too damn wide and too tall. The PO messed with so much stuff on this car to make these stupid tires fit. What do you guys think? Am I missing anything else?? I can't afford wheels and tires after all the cash that went into this so far so i'm limited to just tires. |
| ndfrigi |
Jan 5 2020, 07:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
with 195x60 tires, it should not be that close to the front fender lip/valance. Any picture of the whole tire seeing the whole fender distance? or pic of the rear side of that tire to the fender?
below is 205x60 tire on 15x6 fuch wheel. ![]() |
| mepstein |
Jan 5 2020, 07:41 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It’s the Rivs. That’s a wide tire for them but fine if you have Fuchs.
It shouldn’t be too tall. I have 195x65x15 and it fits fine. Is it a stock valance or aftermarket fiberglass? |
| DickSteinkamp |
Jan 5 2020, 07:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
What do you guys think? Am I missing anything else?? I'm thinking that Rivieras must have less backspacing than most other wheel options. These are 195 65 15s on reproduction 5.5" Fuchs... (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1578276712.1.jpg) No rubbing ever. Not even close. |
| tvdinnerbythepool |
Jan 5 2020, 08:14 PM
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance.
I'm also now thinking the formula for front ride height is not working with the rivieras...ugh Attached thumbnail(s) |
| tvdinnerbythepool |
Jan 5 2020, 08:15 PM
| rhodyguy |
Jan 5 2020, 08:19 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Have you settled the suspension? You need to roll or preferably drive it a bit. By formula, do you mean the Haynes manual?
| tvdinnerbythepool |
Jan 5 2020, 08:25 PM
| mepstein |
The type of wheel won’t make a difference. They just hold the tire in place. You need to go down at least one notch on the torsion bar splines, maybe/probably two.
| burton73 |
Jan 5 2020, 09:14 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
The type of wheel won’t make a difference. They just hold the tire in place. You need to go down at least one notch on the torsion bar splines, maybe/probably two. (IMG:style_emoticons/default/agree.gif) It looks like it is way to high. Bob B |
| ndfrigi |
Jan 5 2020, 09:37 PM
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance. I'm also now thinking the formula for front ride height is not working with the rivieras...ugh maybe too much negative caster or something wrong with the suspension that makes the center wheel towards the front since the picture show there is a lot of space at the rear side. and the lower valance seems bent that makes it leaning inside or that was cause by the tire rubbing to the valance? |
| raynekat |
Jan 5 2020, 09:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance. I'm also now thinking the formula for front ride height is not working with the rivieras...ugh maybe too much negative caster or something wrong with the suspension that makes the center wheel towards the front since the picture show there is a lot of space at the rear side. and the lower valance seems bent that makes it leaning inside or that was cause by the tire rubbing to the valance? I agree with both: too much caster and the lower valance looks off. |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:56 AM |
