> PCV (breather valve) Vacuum hose connection
Montreal914
post Apr 23 2020, 11:55 PM
Is there a reason why I see a lot of engines (2 liter) where the vacuum hose connected to the PCV, by the oil filler, is connected to the air cleaner box whereas in the diagram, it is clearly connected to the plenum? (IMG:style_emoticons/default/confused24.gif)
My guess is that if the PCV ever gets faulty, there will be a vacuum leak in the intake revving up the engine.
Commonly seen (picture from a Google search):
Versus Dave's diagram:
JOEPROPER
post Apr 24 2020, 06:21 AM
The answer is "no" unless you ask...
I think the picture is how late model '75 + '76 is routed, but think it shows earlier... Not 100% sure. I see the an elbow at the intake that is used on earlier cars.(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
Bleyseng
post Apr 24 2020, 11:04 AM
Aircooled Baby!
The PCV hose gets connected to the branched elbow for manifold vacuum not to the air cleaner ports. That pic is just wrong as even the hose is the wrong kind.
914werke
post Apr 24 2020, 11:55 AM
there is no PVC valve on late 75/76 cars
Bleyseng
post Apr 24 2020, 01:22 PM
Aircooled Baby!
Its hard to tell what year setup he is running but as noted there is the 74 stacked elbow on the intake plenum so I assume that is what he is running. but who knows (IMG:style_emoticons/default/confused24.gif)
JeffBowlsby
post Apr 24 2020, 02:01 PM
Oil vapor blow-by piped into the air cleaner pre-filter as shown, would eventually saturate the filter.
Montreal914
It was a 2 liter in a 73 then bumped up to 2056 d-Jet. Now I am converting it to Microsquirt. The PCV is on the oil filler block and I am in the process of connecting the few vacuum hoses needed for the new setup.
I am trying to understand the reason for the case breathing to be connected to the plenum vs the air filter box. Seems to me it increases the potential leaks of the induction setup.
If there is no good reasons to pull vacuum in the block, I would rather connect it to the air box. But since it was designed like that, I am sure there is a reason... Would like to know it. (IMG:style_emoticons/default/beerchug.gif)
Montreal914
post Apr 24 2020, 02:03 PM
QUOTE(JeffBowlsby @ Apr 24 2020, 01:01 PM) *
Makes sense! Thank you for the explanation. (IMG:style_emoticons/default/first.gif)
southernmost914
post Jun 5 2020, 12:28 PM
KEY WEST/HAVANA Tunnel Authority
QUOTE(Montreal914 @ Apr 24 2020, 04:01 PM) *
Here ya go.
https://members.rennlist.com/pbanders/PCV.htm
- Lo-Fi Version Time is now: 2nd April 2026 - 01:16 PM
