warm air blower wiring, new to me motor lacks wires? |
pt_700 |
Sep 12 2020, 02:25 PM
Senior Member Group: Members Posts: 1,093 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
i'm in the process of replacing my 1.7 & trans with a better condition 1.7 & trans from a trusted source. since it's been so many years, it's been helpful to check the "new to me" motor as i disconnect things from the old motor.
i'm stumped on the wires for the hot air blower though. new motor doesn't seem to have them & the wires for the blower on the old motor seem to be part of the harness that stays with the motor. can someone offer enlightenment as to possible differences in the wiring and if i might be able to wire up some sort of bypass, or should i swap over the harness (seems like a lot of work...)? old motor has the 2 hose blower as seen in the pictures. new motor is in the 1st; |
dr914@autoatlanta.com |
Sep 12 2020, 02:32 PM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
looks like everything is correct, fan mounts on top of the blower housing, and the wires are there for in the ignition harness
pt_700 |
Sep 13 2020, 10:17 AM
thanks for chiming in, george. i've looked everywhere on the engine harness and don't see it. i do see, what look to my untrained eye, a few possible modifications (single wires that change color through a connector) though...
there weren't model years that may have had this connect to the relay block? if i can't find the connector, could i wire to somewhere there (a mechanic friend who worked on these new back in the day suggests)? i'll reach out to the seller and see if he can shed some light on this. |
JeffBowlsby |
Sep 13 2020, 10:30 AM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You never mentioned the years of the chassis or engines you have.
If you are talking about a 1970-72 car, they do not have the heater fan wiring in the main chassis harness. The 1970-72 ignition harness supplies the green/brown wires for the heater fan. 1973-76 D-Jet cars include the branch off the main chassis harness for the heater fan and uses a different ignition harness than the earlier models. |
pt_700 |
Sep 13 2020, 10:38 AM
thanks jeff! my car's a '71, the newer motor's an unknown...
sounds like it's '73-76... will this cause other issues as i install and attempt to get it running? |
pt_700 |
Sep 13 2020, 10:49 AM
newer motor came from a '73. thankfully, i found my texts with the seller and he's quick to reply!
JeffBowlsby |
Sep 13 2020, 11:54 AM
The SN will tell you the year.
pt_700 |
Sep 13 2020, 12:27 PM
appears to be; EA093558 (sorry for the poor picture quality).
seller says it was from a '73 and the wires came from the chassis harness "under the fuse panel" (i'm thinking relay board?). how's the air inland jeff? still pretty thick here in san jose, perhaps a mile or two of visibility. i'm surprised there's no smoke smell... |
pt_700 |
Sep 13 2020, 12:41 PM
browsing google images for this subject led to this old thread;
http://www.914world.com/bbs2/index.php?sho...22602&st=20 it would appear to show where i can find power for the blower, yay! thanks 914world! |
JeffBowlsby |
Sep 13 2020, 12:53 PM
162 AQI here today. Staying indoors again today.
Just use the 73-76 ignition harness or get a new one. |
pt_700 |
Sep 13 2020, 04:35 PM
could you please elaborate on the harness, jeff? i'm pretty green when it comes to wiring... it's ok to say it like i'm totally clueless (IMG:style_emoticons/default/slap.gif)
JeffBowlsby |
Sep 13 2020, 07:57 PM
could you please elaborate on the harness, jeff? i'm pretty green when it comes to wiring... it's ok to say it like i'm totally clueless (IMG:style_emoticons/default/slap.gif) For the d-jet cars, there are only 3 variants. A 1970-71 version, a 1972-only, and a 1973-76 version. A main difference is the heater fan circuits. Diagrams of each are on my website if you want to study them. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:09 PM |
