| Tdskip |
Nov 22 2020, 02:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Went looking for a port to connect a vacuum advance and found this on the Weber IDF.
That should be my idle air adjustment and jam nut, right? Anyone know where to source the vacuum port that screws in to the blanking screw on the left? Attached thumbnail(s) |
| IronHillRestorations |
Nov 22 2020, 02:48 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
That's where the air bypass screw should be. It's what you use to balance air flow between barrels
| Tdskip |
Nov 22 2020, 06:52 PM
| Tdskip |
Nov 23 2020, 09:35 AM
Bump for some help (please)...
Can’t seem to find a supplier - believe it is 4mm threaded nipple. Fixed the missing air bleed screw with a donor part from a spare IDF already. |
| yeahmag |
Nov 23 2020, 01:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
| Tdskip |
Nov 23 2020, 05:45 PM
Thanks for the referral. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:39 AM |
