2 Pages V < 1 2
> Oil temp taco plate leaking problem
914werke
post Mar 28 2021, 12:34 PM
Post #21
QUOTE(GregAmy @ Mar 27 2021, 03:26 PM) *
Thanks, Rich.
Any chance you offer one that's just a block off? Race car doesn't measure oil temp there. I could easily use the upper plate and just plug the hole with a bolt...but it won't look as spiffy.
I do offer as an option the plate alone. HERE
Typically offered for the owner with the issue this thread addresses. (IMG:style_emoticons/default/headbang.gif)
They can use their OE sender & just replace the "Taco" plate & cover.
GregAmy
post Mar 28 2021, 02:34 PM
Post #22
THanks, Rich. That's still machined with the threads for a sensor, yes? I was curious if I could just get a flate plate, no hole for sendor.
No biggie, that one will do the same function -- with a bolt in it.
jcd914
post Mar 28 2021, 05:14 PM
Post #23
Most type 4 engines have just a steel plate with no hole for the sensor.
Usually seal well with just the o-ring & copper washers.
Jim
914werke
post Mar 28 2021, 09:26 PM
Post #24
@GregAmy It is.
Jim (IMG:style_emoticons/default/agree.gif) In fact IIRC the OE blanking plate is a bit thicker steel than the stock taco plate.
But, if you after a cover of the same material/expansion rate as the case ... (IMG:style_emoticons/default/aktion035.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 06:49 AM
