| Villemi |
Dec 20 2021, 01:57 PM
Newbie ![]() Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France |
Hello
I have december 75 2.0l Porsche 94 My car is an US one and had a canister and air pump. For late 74 diagram it was this one (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640074350.1.jpg) I don't have any more the canister and the air pump My car has no anti flash back valve too. Are you agree with the new diagram for my late 75 car ? (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640039023.1.jpg) It's difficult to understand when you have a 46years old !!! |
| rjames |
Dec 20 2021, 02:58 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
You’re missing the decel valve. Isn’t necessary for the car to run, but it may prolong the life of your MPS.
It will also help with emissions by leaning out the mixture on deceleration. |
| JeffBowlsby |
Dec 20 2021, 03:15 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Please take my name off your modified diagram and retitle it for your purposes, as a courtesy to me. You can replace the diagram in the first post and delete the diagram posted. While I understand what his diagram is intended to do, it can take a life of its own if it gets circulated on the internet and its purpose is misunderstood.
I would not change a thing from diagram, as you describe your car. Find a flashback valve, decel valve and charcoal canister and hook them up. You will be glad you did. |
| Villemi |
Dec 20 2021, 04:26 PM
Hello Jeff,
Excuse me for using your diagram I'm confused. Thank you for your answer and help. For the charcoal canister everything is out of the car. My car had no flashback fire and no nipple on cylinder. In Europe the 914 cars have not these parts. |
| Villemi |
Dec 20 2021, 04:45 PM
You’re missing the decel valve. Isn’t necessary for the car to run, but it may prolong the life of your MPS. It will also help with emissions by leaning out the mixture on deceleration. Can you explain to me how the decel valve is very ilmprtant for the MPS please. I've seen somewhere that the decel valve was only for 1.7l and 1.8l 914. |
| JeffBowlsby |
Dec 20 2021, 06:48 PM
Hello Jeff, Excuse me for using your diagram I'm confused. Thank you for your answer and help. For the charcoal canister everything is out of the car. My car had no flashback fire and no nipple on cylinder. In Europe the 914 cars have not these parts. Thank you Villemi. Please edit your first post to delete the first photo with my name on it. I am flattered by your use of may diagram to create your diagram, but you have edited it and my name is attached to it, where I have no control over your diagram. As for the charcoal canister and flashback valve they are USA emissions requirements and may not be needed in Europe, but they do serve a good purpose. The charcoal canister reduces petrol fumes in the cabin and the flashback valve (spark arrestor) safely reduces crackcase pressures. Try and locate and install them to your benefit. I further would not run the PCV valve hose to the filter box to prevent oil contamination of your air filter, put it on the intake planeum as my diagram shows. |
| Villemi |
Dec 21 2021, 02:19 AM
Hello Jeff, Excuse me for using your diagram I'm confused. Thank you for your answer and help. For the charcoal canister everything is out of the car. My car had no flashback fire and no nipple on cylinder. In Europe the 914 cars have not these parts. Thank you Villemi. Please edit your first post to delete the first photo with my name on it. I am flattered by your use of may diagram to create your diagram, but you have edited it and my name is attached to it, where I have no control over your diagram. As for the charcoal canister and flashback valve they are USA emissions requirements and may not be needed in Europe, but they do serve a good purpose. The charcoal canister reduces petrol fumes in the cabin and the flashback valve (spark arrestor) safely reduces crackcase pressures. Try and locate and install them to your benefit. I further would not run the PCV valve hose to the filter box to prevent oil contamination of your air filter, put it on the intake planeum as my diagram shows. And for the decel valve ? I have this part . Is it mandatory for the MPS healf ? |
| BeatNavy |
Dec 21 2021, 06:04 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0
Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? |
| Villemi |
Dec 21 2021, 07:03 AM
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? Yes thank you, And for the fashback valve ? Mandatory ? I don't understand where the hoses ar connected on the engine Pics possible ? |
| BeatNavy |
Dec 21 2021, 07:17 AM
Flashback valve is another item that's not "mandatory" but is there for protection / prevention. Just like the decel valve, car will run fine without it, but I wouldn't recommend it. One hose from each head routes to it and then a third to the air cleaner.
It's supposed to relieve some crankcase pressure, provide some emissions control, and prevent a backfire flame from reaching the crankcase, IIRC. It's also called a "spark arrestor." Here's a pic (not mine). Two hoses on bottom -- one to each head, one on top to the air cleaner. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-17042-1640092632.1.jpg) |
| StarBear |
Dec 21 2021, 07:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,259 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? @BeatNavy 20 psi or 20 in Hg? I think I saw the latter recently on the 1.8L idle issue thread. |
| BeatNavy |
Dec 21 2021, 08:04 AM
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? @BeatNavy 20 psi or 20 in Hg? I think I saw the latter recently on the 1.8L idle issue thread. Correct, inches mercury. Sorry for confusion. So I guess 20 in HG converts to more like .7 bar. I corrected my original post. |
| DRPHIL914 |
Dec 21 2021, 08:36 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? Yes thank you, And for the fashback valve ? Mandatory ? I don't understand where the hoses ar connected on the engine Pics possible ? @Villemi in 1975-1976 the factory did not put head vents on these cars and therefore no antiflash back valve, futhermore if you look at the research on this by LN engineering, Len Hoffman and Jake Raby did they found it better NOT to vent the heads( i just found this out last week and read thru all their research and documentation they did) - so you can follow the diagrams but if your heads are US heads with no vent then you will not hook up the anti-flash back valve. ALSO 75-76 US cars did not have a PVC the factory deleted it. I would not use a PVC , the stack at the oil filler is different, but what i would do and oh i did do is i connected the crank case vent hose to a catch can and that to the air cleaner. That will keep the oil vaper out of your air filter like Jeff said. If you put the hose to the manifold like the early cars had you are going to have what will amount to a high idle due to pulling too much air , just like a vac leak. - so - late cars had no PVC no head vents and no flash back valve. Phil |
| TX914 |
Dec 21 2021, 09:01 AM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
| DRPHIL914 |
Dec 21 2021, 09:37 AM
(IMG:style_emoticons/default/agree.gif) i left that off but i think that is the general concensus that with Djet you should have the decel valve hooked up, to help prevent an issue with the MPS- i need to put mine back on. one other issue is that in the US these cars had the smog pump too but those are long gone and i have never seen a car with one on that worked, so there would be that air injection port on the head at the exhaust port that would be plugged if all the smog stuff is removed. |
| BeatNavy |
Dec 21 2021, 09:52 AM
Phil is correct. Something else I didn't key on -- your heads likely don't have vents. Can't hook up a flashback valve if you don't have head vents.
And Phil's right, Len Hoffman recommends against the head venting. On the heads he did for my 2056 he plugged up the vent. I'm full of all kinds of (mis) information today (IMG:style_emoticons/default/wink.gif) |
| StarBear |
Dec 21 2021, 11:01 AM
Phil is correct. Something else I didn't key on -- your heads likely don't have vents. Can't hook up a flashback valve if you don't have head vents. And Phil's right, Len Hoffman recommends against the head venting. On the heads he did for my 2056 he plugged up the vent. I'm full of all kinds of (mis) information today (IMG:style_emoticons/default/wink.gif) Either not enough beer or too much, probably. Easy to correct if the first case. (IMG:style_emoticons/default/beerchug.gif) |
| Villemi |
Dec 21 2021, 04:25 PM
After this discuss do you validate my diagram ?
On my car I'have the decel valve, no charcoal ,no PCV, no air pump, no flashback valve. (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640127282.1.jpg) |
| Bleyseng |
Dec 21 2021, 04:31 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
That looks correct but you will have to plug the 13mm fitting at the stack nipple without the charcoal hose going to it.
Do you have a throttle body with 2 ports? If so you can hook uip the vacuum advance hose to one of them instead of it laying there underneath the runners. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:12 AM |
