| shredtherad |
May 27 2022, 05:08 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
Hello, hello! The new to me 914 is so rad! Love it... went out for a bit of cruise and about 20+ mins into the drive, while approaching a trafific light ( red ) the car came down to idle and that kept going and poof... stall. It did not start, I blocked the lane and angry SUV's and Tesla's honked at me. I did however get it going again after putting the pedal to the floor while starting and it fired up and drove fine, until... idle at the stop sign. Poof, stall. BUT this time pedal to the floor and fired right up.
Thoughts, where should I begin. I have attached a video of the issue... thanks! Beep Beep. https://www.youtube.com/watch?v=Mx47LENYFuU |
shredtherad Honk Honk!.... " yea, I know I am stalled out and blocking the intersection @$$H*L$" May 27 2022, 05:08 PM
Big Len I think the first general question would be carbs ... May 27 2022, 05:22 PM
shredtherad
I think the first general question would be carbs... May 27 2022, 08:45 PM
emerygt350 So sorry! What is the year and fuel system? C... May 27 2022, 05:23 PM
shredtherad
So sorry! What is the year and fuel system? ... May 27 2022, 08:45 PM
Superhawk996 Watched your video. By video title it says stock ... May 27 2022, 05:44 PM
shredtherad
Watched your video. By video title it says stock... May 27 2022, 08:48 PM
r_towle
[quote name='Superhawk996' post='3004559' date='M... May 28 2022, 08:52 AM
shredtherad
[quote name='Superhawk996' post='3004559' date='... May 28 2022, 08:57 AM
76-914 So it takes about 20 min's before this happens... May 27 2022, 05:58 PM
shredtherad
So it takes about 20 min's before this happen... May 27 2022, 08:50 PM
wonkipop factory workshop manual
you can download.
http:/... May 27 2022, 08:47 PM
mgphoto First test is simple, get a hand vacuum pump with ... May 27 2022, 09:57 PM
GregAmy
First test is simple, get a hand vacuum pump with... May 28 2022, 06:53 AM
shredtherad
First test is simple, get a hand vacuum pump wit... May 28 2022, 08:57 AM
shredtherad
[quote name='mgphoto' post='3004625' date='May 27... May 28 2022, 09:00 AM
Lockwodo
[quote name='GregAmy' post='3004653' date='May 28... May 28 2022, 10:31 AM
shredtherad
First test is simple, get a hand vacuum pump with... May 28 2022, 08:56 AM
brant Can you hear the pump run when it’s acting up an... May 29 2022, 06:56 AM
shredtherad
Can you hear the pump run when it’s acting up a... May 29 2022, 08:31 AM
rhodyguy This is a MittyvacII. You will know if the diaphra... May 29 2022, 08:35 AM
shredtherad
This is a MittyvacII. You will know if the diaphr... May 29 2022, 10:49 AM
shredtherad All, thanks for the replies and insights
I teste... May 29 2022, 10:54 AM
brant So that creates an ultra rich condition and the re... May 29 2022, 12:40 PM
brant There is also an O’ring inside to seal the MPS c... May 30 2022, 09:04 AM
shredtherad
There is also an O’ring inside to seal the MPS ... May 30 2022, 05:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:51 PM |
