| shredtherad |
May 27 2022, 05:08 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
Hello, hello! The new to me 914 is so rad! Love it... went out for a bit of cruise and about 20+ mins into the drive, while approaching a trafific light ( red ) the car came down to idle and that kept going and poof... stall. It did not start, I blocked the lane and angry SUV's and Tesla's honked at me. I did however get it going again after putting the pedal to the floor while starting and it fired up and drove fine, until... idle at the stop sign. Poof, stall. BUT this time pedal to the floor and fired right up.
Thoughts, where should I begin. I have attached a video of the issue... thanks! Beep Beep. https://www.youtube.com/watch?v=Mx47LENYFuU |
| Big Len |
May 27 2022, 05:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,779 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
I think the first general question would be carbs or FI?
| emerygt350 |
May 27 2022, 05:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,508 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
So sorry! What is the year and fuel system? Carb or injected?
| Superhawk996 |
May 27 2022, 05:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Watched your video. By video title it says stock so I'm going to roll with fuel injected.
Problem is I think you're looking for an easy agreed upon solution to your problem. You're going to get plenty of opinions or "his fixed my car" responses which might help or might have zero applicability to your problem and will keep you running in circles. If you're new to 914's, and 50 year old fuel injection, you should probably start familiarizing yourself with the Brad Anders pages and the overview of D-jet fuel injection components and how to troubleshoot them. https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot (IMG:style_emoticons/default/welcome.png) |
| 76-914 |
May 27 2022, 05:58 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
So it takes about 20 min's before this happens? If so I think we can rule out vacuum leaks as that would increase the idle speed. Rule out the TPS idle circuit as that would be wonky warm or cold. Does your ECU have a black know on top. If so that controls the idle circuit. You can figit with that. IIRC, it has 22 clicks rich to lean. If that does nothing check to see.if the vacuum is holding on the MPS. That's also in Blander's D Jet Bible. Once warmed up check the ohm reading on the CHT sender on cylinder 3. The values are also listed in Blander's Bible. If you have L Jet disregard everything I said. Good luck and if it (IMG:style_emoticons/default/sheeplove.gif) with you too much throw a Subaru drive train in it. (IMG:style_emoticons/default/happy11.gif)
| shredtherad |
May 27 2022, 08:45 PM
| shredtherad |
| wonkipop |
May 27 2022, 08:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
| shredtherad |
May 27 2022, 08:48 PM
Watched your video. By video title it says stock so I'm going to roll with fuel injected. Problem is I think you're looking for an easy agreed upon solution to your problem. You're going to get plenty of opinions or "his fixed my car" responses which might help or might have zero applicability to your problem and will keep you running in circles. If you're new to 914's, and 50 year old fuel injection, you should probably start familiarizing yourself with the Brad Anders pages and the overview of D-jet fuel injection components and how to troubleshoot them. https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot (IMG:style_emoticons/default/welcome.png) Yup, 73 1.7 with FI. Of course I am looking for the easy fix (IMG:style_emoticons/default/smile.gif) but know that is not what is going to happen, I do however need to start somewhere. Thanks for the link! I will be reading that one! |
| shredtherad |
May 27 2022, 08:50 PM
So it takes about 20 min's before this happens? If so I think we can rule out vacuum leaks as that would increase the idle speed. Rule out the TPS idle circuit as that would be wonky warm or cold. Does your ECU have a black know on top. If so that controls the idle circuit. You can figit with that. IIRC, it has 22 clicks rich to lean. If that does nothing check to see.if the vacuum is holding on the MPS. That's also in Blander's D Jet Bible. Once warmed up check the ohm reading on the CHT sender on cylinder 3. The values are also listed in Blander's Bible. If you have L Jet disregard everything I said. Good luck and if it (IMG:style_emoticons/default/sheeplove.gif) with you too much throw a Subaru drive train in it. (IMG:style_emoticons/default/happy11.gif) Excellent! A bunch to dig into here! Thx… many subie 914’s out there? |
| mgphoto |
May 27 2022, 09:57 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop.
Sounds like a cracked diaphragm, runs rich when that happens. |
| GregAmy |
May 28 2022, 06:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop. Sounds like a cracked diaphragm, runs rich when that happens. Was my first thought, since I had similar symptoms with the 2L D-Jet. If you're running stock D-Jet, and you have more than say, 75-100k miles on the car, you have no evidence that the diaphragm has ever been replaced, then I'd wager a dollar to every donut that your diaphragm needs to be replaced. The MPS was a very clever design for its time but that diaphragm has a life limit before it will absolutely fatigue. Mine had those, and other symptoms, and it actually passed the vac test! But when Tangerine pulled it apart to rebuild the crack was obvious. And replacing it transformed the way the car drove. I like D-Jet, I think it's worth saving. Consider sending your MPS to Chris for a new diaphragm, even if it passes a vac test. http://www.tangerineracing.com/mpsdiaphragm.htm |
| r_towle |
May 28 2022, 08:52 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Watched your video. By video title it says stock so I'm going to roll with fuel injected. Problem is I think you're looking for an easy agreed upon solution to your problem. You're going to get plenty of opinions or "his fixed my car" responses which might help or might have zero applicability to your problem and will keep you running in circles. If you're new to 914's, and 50 year old fuel injection, you should probably start familiarizing yourself with the Brad Anders pages and the overview of D-jet fuel injection components and how to troubleshoot them. https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot (IMG:style_emoticons/default/welcome.png) Yup, 73 1.7 with FI. Of course I am looking for the easy fix (IMG:style_emoticons/default/smile.gif) but know that is not what is going to happen, I do however need to start somewhere. Thanks for the link! I will be reading that one! An easy fix is to plan your trips to be less than 20 minutes |
| shredtherad |
May 28 2022, 08:56 AM
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop. Sounds like a cracked diaphragm, runs rich when that happens. I have this one on the list, I will go down the list and start checking them off. I don't have the pump/gauge but can pick one up. I will have to remove the MPS? |
| shredtherad |
May 28 2022, 08:57 AM
Watched your video. By video title it says stock so I'm going to roll with fuel injected. Problem is I think you're looking for an easy agreed upon solution to your problem. You're going to get plenty of opinions or "his fixed my car" responses which might help or might have zero applicability to your problem and will keep you running in circles. If you're new to 914's, and 50 year old fuel injection, you should probably start familiarizing yourself with the Brad Anders pages and the overview of D-jet fuel injection components and how to troubleshoot them. https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot (IMG:style_emoticons/default/welcome.png) Yup, 73 1.7 with FI. Of course I am looking for the easy fix (IMG:style_emoticons/default/smile.gif) but know that is not what is going to happen, I do however need to start somewhere. Thanks for the link! I will be reading that one! An easy fix is to plan your trips to be less than 20 minutes haha... basically what I have been doing (IMG:style_emoticons/default/smile.gif) |
| shredtherad |
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop. Sounds like a cracked diaphragm, runs rich when that happens. Was my first thought, since I had similar symptoms with the 2L D-Jet. If you're running stock D-Jet, and you have more than say, 75-100k miles on the car, you have no evidence that the diaphragm has ever been replaced, then I'd wager a dollar to every donut that your diaphragm needs to be replaced. The MPS was a very clever design for its time but that diaphragm has a life limit before it will absolutely fatigue. Mine had those, and other symptoms, and it actually passed the vac test! But when Tangerine pulled it apart to rebuild the crack was obvious. And replacing it transformed the way the car drove. I like D-Jet, I think it's worth saving. Consider sending your MPS to Chris for a new diaphragm, even if it passes a vac test. http://www.tangerineracing.com/mpsdiaphragm.htm Cool, I will do this test. Thanks! |
| shredtherad |
May 28 2022, 09:00 AM
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop. Sounds like a cracked diaphragm, runs rich when that happens. Was my first thought, since I had similar symptoms with the 2L D-Jet. If you're running stock D-Jet, and you have more than say, 75-100k miles on the car, you have no evidence that the diaphragm has ever been replaced, then I'd wager a dollar to every donut that your diaphragm needs to be replaced. The MPS was a very clever design for its time but that diaphragm has a life limit before it will absolutely fatigue. Mine had those, and other symptoms, and it actually passed the vac test! But when Tangerine pulled it apart to rebuild the crack was obvious. And replacing it transformed the way the car drove. I like D-Jet, I think it's worth saving. Consider sending your MPS to Chris for a new diaphragm, even if it passes a vac test. http://www.tangerineracing.com/mpsdiaphragm.htm https://youtu.be/3lvTXN7d5-8 This seems like a good video/resource |
| Lockwodo |
May 28 2022, 10:31 AM
Member ![]() ![]() Group: Members Posts: 239 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
First test is simple, get a hand vacuum pump with a gauge, test the MPS, pull 10 to 15 in Hg and see how long it takes to drop. Sounds like a cracked diaphragm, runs rich when that happens. Was my first thought, since I had similar symptoms with the 2L D-Jet. If you're running stock D-Jet, and you have more than say, 75-100k miles on the car, you have no evidence that the diaphragm has ever been replaced, then I'd wager a dollar to every donut that your diaphragm needs to be replaced. The MPS was a very clever design for its time but that diaphragm has a life limit before it will absolutely fatigue. Mine had those, and other symptoms, and it actually passed the vac test! But when Tangerine pulled it apart to rebuild the crack was obvious. And replacing it transformed the way the car drove. I like D-Jet, I think it's worth saving. Consider sending your MPS to Chris for a new diaphragm, even if it passes a vac test. http://www.tangerineracing.com/mpsdiaphragm.htm https://youtu.be/3lvTXN7d5-8 This seems like a good video/resource Yes, that will show you how to test the vacuum integrity and the primary/secondary coil wiring. For troubleshooting MPS and other 914 problems in general, another good resource is the Tech Notebook: https://bowlsby.net/914/Classic/TechNotebook.htm, see Reference Manual section. |
| brant |
May 29 2022, 06:56 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Can you hear the pump run when it’s acting up and you first turn the key on?
I’ve got a vacuum test gauge , a fuel pressure test gauge and ohm meter if you want to borrow Brant |
| shredtherad |
May 29 2022, 08:31 AM
Can you hear the pump run when it’s acting up and you first turn the key on? I’ve got a vacuum test gauge , a fuel pressure test gauge and ohm meter if you want to borrow Brant Thanks Brant, I will have to replicate the issue and see if the pump is running, from cold start it is running. The issue starts after the car is hot. Appreciate the offer of the tools. I might take you up on it. CT |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:24 AM |
