> Cylinder Head Temp Sensor?
Puebloswatcop
post Dec 18 2022, 08:07 AM
Is a cylinder head temp sensor needed on a carburated car? It seems it is just for the "computer" on an FI car, but I need to clarify.
914Sixer
post Dec 18 2022, 08:10 AM
NOT required
Puebloswatcop
post Dec 18 2022, 08:17 AM
QUOTE(914Sixer @ Dec 18 2022, 08:10 AM) *
NOT required
Thanks,
Didn't think so, but wanted some expert confirmation
930cabman
post Dec 18 2022, 11:35 AM
The cyl head sensor is not required for the engine to run, but it's information. I will be running one on the build I am currently working on. It could be helpful if your carbs are getting on the lean side.
Dave_Darling
post Dec 18 2022, 10:25 PM
914 Idiot
Note that the stock CHT sensor is not the same type as those used by the CHT gauges. It's also in an area of the head that changes fairly slowly. It's not a good data source for telling you much of anything about the engine.
Use the ring-type thermocouple around the spark plug which is the standard way to get CHT readings.
--DD
930cabman
post Dec 19 2022, 06:01 AM
QUOTE(Dave_Darling @ Dec 18 2022, 11:25 PM) *
--DD
(IMG:style_emoticons/default/headbang.gif)
Thank you Dave, I have also read the same, under the spark plug is the most accurate location for cyl head temp. Can this be problematic when changing spark plugs? I can see the ring getting lost when threading a new plug into the head
BeatNavy
post Dec 19 2022, 06:57 AM
The ring is attached to a long wire that leads to your display. So no, the ring shouldn't be at risk of getting lost. At least that's how it is on my Dakota Digital setup.
Putting it on the plug and then getting the plug in the head can be slightly tricky, particularly if the head hasn't had any material removed to allow the room for the ring/wire so they can sit flat aginst the head. On one set of heads I used a dremel to cut away some relief. I think the AAA heads now are cast with a relief already there.
VaccaRabite
post Dec 19 2022, 08:35 AM
En Garde!
QUOTE(930cabman @ Dec 19 2022, 07:01 AM) *
--DD
Just grind a little groove into the boss for the wire to exit under the park plug. No big deal.
The first time you put in the plug it will be challenging. But you figure out how to do it and it is easy the rest of the time. You just have to rememeber to remove the washer from the plug you have the temp sender on.
Zach
stownsen914
post Dec 20 2022, 11:29 AM
Is it feasible to put the sparkplug ring sensor at the stock CHT sensor location (presumably using a bolt)?
GregAmy
post Dec 20 2022, 11:49 AM
QUOTE(stownsen914 @ Dec 20 2022, 12:29 PM) *
You can, but it won't be useful info.
First, that location never gets as hot, or reacts as fast, as under the spark plugs.
Second - and most importantly - given "first" above you will not be able to compare that information to long-standing historical background:
http://www.914world.com/bbs2/index.php?sho...mp;#entry377466
Do it at the CHT if you just want another interesting gauge in the car. But if you want useful info, put it under the spark plug.
GA
barefoot
post Dec 21 2022, 07:32 AM
TC mounted under #3 spark plug should be clamped down with something like this :
I made my own. Have changed plugs since, no issues.
emerygt350
post Dec 21 2022, 07:50 AM
I just put mine in through the spark plug hole in the tin (cylinder 3, if no one has mentioned it yet) and I am just careful when installing new plugs. Do it the right way if you have the engine out though.
barefoot
post Dec 22 2022, 09:25 AM
QUOTE(emerygt350 @ Dec 21 2022, 08:50 AM) *
If you didn't put a grommet over the TC wire where it meets the tin it could chafe thru and then you'd likely be reading temperature of the tin itself (IMG:style_emoticons/default/screwy.gif)
Lockwodo
post Dec 22 2022, 06:34 PM
Hi all. I want to add a cylinder 3 thermocouple and gauge to my '74 2.0. I brought, but have not yet installed, the setup in the attachment below. Question: I don't like the look of the digital gauge, can someone suggest a traditional needle type temperature gauge that would work with this thermocouple? Something that matches the stock gauges would be great.
Thanks, Doug
VaccaRabite
post Dec 22 2022, 06:51 PM
En Garde!
https://www.aircraftspruce.com/menus/in/falcon_cht.html
Pck the one you like.
Make sure it is temp compensated, and uses a ring type thermocouple (I THINK its a K type).
But speaking from experience, the Dakota Digital is THE gauge to have, even though it is a digital readout. Its the one I have in my car, and in my bus, and will have in my dune bug.
Zach
GregAmy
post Dec 22 2022, 07:21 PM
Quick side note for you data acq guys/gals.
Sensor Connection $35 K-type thermocouple:
http://thesensorconnection.com/cht-sensors...re-12-and-14-mm
Plus $12 Adafruit amplifier:
https://www.adafruit.com/product/1778
...makes a damned fine input to your system. I'm using it into my Microsquirt ECU for the street car, and into my data acq system on the race car. It's also being used as a failsafe "cut over" for either altermate maps (street car) or "you're being stuipid light" (race car).
If you must have a gauge, I have one of these, with enclosure, sitting in my toolbox I'd be glad to pass along in exchange for a case of your local IPA:
http://thesensorconnection.com/egt-probe-t...egt_meter.shtml
GA
- Lo-Fi Version Time is now: 2nd April 2026 - 09:57 AM
