| nivekdodge |
Feb 12 2023, 08:42 PM
Member ![]() ![]() Group: Members Posts: 331 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
My car (carbs) came with a Facet fuel pump and it’s really loud. It’s fits where I put it and it’s economical. Are they all that loud?
Kevin |
| Superhawk996 |
Feb 12 2023, 08:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Yup.
| 76-914 |
Feb 12 2023, 08:54 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I had one in an airplane and I could hear it whenever I flipped it on. Luckily it was only used during takeoff & landing. Otherwise I would have replaced it. (IMG:style_emoticons/default/mad.gif)
| nivekdodge |
Feb 12 2023, 09:29 PM
So it is working correctly then.
| bdstone914 |
Feb 12 2023, 09:58 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@nivekdodge
date='Feb 12 2023, 09:29 PM' post='3057690'] So it is working correctly then. [/quote] The noise is dampened somewhatvifvit has rubber isolation mounts. Or get a rotarty pump. |
| ClayPerrine |
Feb 13 2023, 06:51 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
| rhodyguy |
Feb 13 2023, 08:25 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What is the fuel pressure set at? Is the gauge accurate? They make a terrible racket mounted directly to metal.
| 930cabman |
Feb 13 2023, 10:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,571 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I have ran a Facet for several years on a couple different sporting machines without a problem, but just ordered a Pierburg. I will keep a facet for a backup.
| NARP74 |
Feb 13 2023, 11:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
It's great for solving fuel problems. You can always tell it is working and move on to something else.
| ClayPerrine |
Feb 13 2023, 12:21 PM
| porschetub |
Feb 13 2023, 12:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So it is working correctly then. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) built in to tell you it is still working which they do ,they seem to be very reliable cause there is little to wear out. |
| rhodyguy |
Feb 13 2023, 05:25 PM
A facet pump, a battery, jumper cables, some hose lengths and a few catch cans make short work of emptying a fuel tank.
| Osnabruck914 |
Feb 13 2023, 05:45 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Whoever designed the Facet pump should be brought up on charges. It was the first thing I changed out when I got my carbureted 914. Absolutely get a rotary pump.
Osnabruck914 |
| GBX0073 |
Feb 13 2023, 10:27 PM
Member ![]() ![]() Group: Members Posts: 185 Joined: 21-December 20 From: Illinois Member No.: 25,007 Region Association: Upper MidWest
It's True with the Facet you know it's working when you hear it
Had my 914 stall down the block right away I did not hear the pump so switched the relay from the heater fan and the Facet started buzzing and I was on my way ! Question to the group I have dual Weber's If I get a Pierburg can I get by without the regulator? |
| 930cabman |
Feb 14 2023, 05:53 AM
Whoever designed the Facet pump should be brought up on charges. It was the first thing I changed out when I got my carbureted 914. Absolutely get a rotary pump. Osnabruck914 (IMG:style_emoticons/default/av-943.gif) firing squad maybe |
| rhodyguy |
Feb 14 2023, 09:10 AM
Zims states a FP regulator is required for that pump if used with carbs. 5.5 lbs pressure. With an adj regulator you would need a GOOD, ACCURATE gauge. Lots more money. With a quality reg and gauge you can stay with the facet and live with the racket. I think the LP CB or Carter pumps do not require a regulator.
| ClayPerrine |
Feb 14 2023, 09:21 AM
In the 356 section on Zims site, there is a 12v pump for carbs that doesn't require a regulator.
But the Pierburg is a better pump. Clay |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:49 AM |
