| tygaboy |
Feb 9 2023, 10:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,803 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
| BillJ |
Feb 9 2023, 10:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
Yes building a legal 2.4 on the off chance they check. It is pricier to do that way because it requires custom Ps and Cs. Having LN do those. Also having Extreme do the heads. Hope it will work out well.
The car did previously have a 2.7rs-ish motor. The issue with that is of course it is in the same class as the 3ltr RSRs which it just cannot compete with (at least with me driving) and its too big to run in the up to 2.5 class. According to a couple of the groups i run with one cannot build larger than 2399cc. There are quite a few cars in the under 2.5 ltr class as well and looking forward to compete and have fun. |
| BillJ |
Feb 9 2023, 10:41 PM
Collecting more goodies to be installed for the new buildout. Would you be willing to share where you got those exhaust tips? Or did you make them?Thanks. Sierra Madre sells the bursch line. They include silenced and non silenced in a couple different finishes. I had some made that are just the pipes with cookie cutters but wanted something for tracks with noise limits. https://sierramadrecollection.com/products/...hone-set-p55902 |
| BillJ |
Feb 18 2023, 04:44 PM
Latest update is that i got new steering wheel and as it is dished it was too close to me when harnessed in. So got a shorter hub adapter from rennline and installed today. Much much better and it looks pretty clean now as well.
| Dion |
Feb 18 2023, 04:53 PM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region
This is coming along so nicely. That will be a nice power plant for sure. Looking forward to more.
| BillJ |
Feb 19 2023, 03:47 AM
| BillJ |
Mar 23 2023, 05:26 PM
I shared case pictures before but now have the heads from Extreme Heads in FL to share. These are custom billet heads specifically designed for this engine. Excited to see how they work and certainly hope they live up to the hype. This is the shop that builds the heads for the Singer cars...
Attached thumbnail(s) |
| DRPHIL914 |
Mar 24 2023, 12:04 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
| Maltese Falcon |
Mar 24 2023, 05:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Hi Bill, the cyl heads resemble Cusimano "D" port billet heads of the 935 days, some lucky 930 Street guys ran these too (IMG:style_emoticons/default/biggrin.gif) Love this 9146 racer/ restoration!! Good call on the fire suppression Foam...I'm stealing your idea & putting this into the 8-gtt build.
Marty (IMG:style_emoticons/default/number40_914.jpg) |
| gms |
Mar 26 2023, 09:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
Bill those heads are works of art!!
| Superhawk996 |
Mar 26 2023, 11:57 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| BillJ |
Mar 26 2023, 02:12 PM
So the case i sourced out of AASE had already had all the work completed (aside from boattailing which the builder has done) and did NOT include shuffle pinning. There are differing opinions out there but many say on the magnesium cases that you should not pin due to higher risk of cracks developing. Aluminum cases from what i heard should be.
| BillJ |
Mar 26 2023, 07:23 PM
New upgrade will be this comms system for racing. May certainly come in handy especially for longer runs and for knowing when that green flag is flying! Helmet is already wired and has correct plug, mic, and speakers so all i have to do is install in the car.
| BillJ |
Apr 5 2023, 08:47 AM
Build has started in earnest. Here are some pics to enjoy (IMG:style_emoticons/default/beerchug.gif)
| BillJ |
Apr 5 2023, 08:49 AM
One more
| ClayPerrine |
Apr 5 2023, 08:55 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Did you do the oil pressure relief mod on the case?
| BillJ |
Apr 5 2023, 09:12 AM
Did you do the oil pressure relief mod on the case? Yep all good there (IMG:style_emoticons/default/evilgrin.gif) The case was fully worked by ollies. Only thing not done was shuffle pin and that was intentionally due to being mag. If was aluminum then it would have been done as well. |
| BillJ |
Apr 5 2023, 09:19 AM
Heads as done by Extreme
| BillJ |
Apr 5 2023, 10:28 AM
Head and the custom jes with LN Nickies
| BillJ |
Apr 7 2023, 12:06 PM
Well the bearings came in and the bottom end is now sealed up! Getting excited.
Lo-Fi Version | Time is now: 2nd April 2026 - 11:23 AM |
