| slapshot |
Aug 31 2023, 12:45 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains
Yesterday just before getting home I heard a click from the engine then again. It wasn't steady, just every little bit I would hear it. I could feel that I lost power and it even stalled once at a stop light. Since I was only a couple block from home I just keep going.
I found that cylinder 3 could only produce 20 lbs of compression. A leak down test was 22% with most air coming out of the intake. For reference the other cylinders were 100 to 105 compression and the leak down was 18% to 20% with air noticed just in the oil filler hole. I don't know how accurate my testing tools are since they are cheap ones I got from amazon and harbor freight. I took off of my valve cover for cylinders 3 and 4 and with cylinder 3 at TDC I have over 1/2 inch of play with both valves and the pushrods are of course way loose. I haven't removed the rockers to pull the pushrods out yet to see if they are bent. I will do that after I pulling the engine either tomorrow or this weekend. How screwed am I? Thoughts on best and worse case? Here's a video of my loose rocker Video of rockers |
slapshot Whats that click in my engine Aug 31 2023, 12:45 PM
r_towle you may have dropped a valve seat which will wedge... Aug 31 2023, 01:42 PM
brant
you may have dropped a valve seat which will wedg... Aug 31 2023, 05:25 PM
slapshot I will check for that. That doesn't sound too... Aug 31 2023, 02:20 PM
914sgofast2 Unfortunately, it's probably best to start sav... Aug 31 2023, 02:21 PM
DRPHIL914
I will check for that. That doesn't sound to... Aug 31 2023, 02:43 PM
slapshot 914sgofast2, what is P&C's? Pistons and c... Aug 31 2023, 03:18 PM
DRPHIL914
914sgofast2, what is P&C's? Pistons and ... Sep 1 2023, 06:33 AM
rhodyguy End result, to me, is a complete rebuild and EVERY... Sep 1 2023, 08:30 AM
brant Who built the failing heads?
There just are not m... Sep 1 2023, 08:34 AM
slapshot Thanks for all the information.
I've only had... Sep 1 2023, 03:12 PM
ndfrigi Hoping that is the only issue and can be fix and a... Sep 1 2023, 04:08 PM
slapshot
Hoping that is the only issue and can be fix and ... Sep 1 2023, 11:40 PM
914sgofast2 Looks like the engine was “rebuilt” by GEX. Go... Sep 1 2023, 08:43 PM
slapshot
Looks like the engine was “rebuilt” by GEX. G... Sep 7 2023, 05:03 PM
slapshot I retapped the bolt, put the rocker back on and se... Sep 1 2023, 11:47 PM
porschetub
I retapped the bolt, put the rocker back on and s... Sep 2 2023, 01:54 PM
slapshot I torqued them to 10ft/lbs. I put the engine back... Sep 2 2023, 07:05 PM
porschetub
I torqued them to 10ft/lbs. I put the engine bac... Sep 4 2023, 02:20 PM
slapshot 52 sounds about right. My reading indicates that ... Sep 5 2023, 09:32 PM
DRPHIL914
52 sounds about right. My reading indicates that... Sep 6 2023, 06:27 AM
porschetub
52 sounds about right. My reading indicates that... Sep 16 2023, 10:34 PM
slapshot
[quote name='slapshot' post='3100246' date='Sep 6... Sep 17 2023, 09:16 PM
ndfrigi Congratulations! thanks for the update too... Sep 5 2023, 10:19 PM
slapshot DRPHIL914-- I am now fluent in dropping that suck... Sep 7 2023, 05:10 PM
slapshot I thought I would give an update here just incase ... Sep 15 2023, 01:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:51 PM |
