> Encapsulate Grounds in Butyl ?
Literati914
post Mar 28 2025, 02:07 PM
Having read so many threads recommending to check grounds for various issues- I've been thinking about adding well formed "caps" made of Butyl tape ('cause I got plenty on hand).
Besides being a little messy upon disassembly, particularly on ground points with multiple grounds - are there any less-than-obvious drawbacks to using butyl rubber tape to form encapsulating 'caps' for the purpose of corrosion protection over ground points? I'd be considering this for exterior grounds lug areas in particular. I know there are specific products for this purpose but I've got plenty of butyl on hand and it kind of seems more permanent too. Anyone done this?
Root_Werks
post Mar 28 2025, 02:16 PM
Village Idiot
You know, may not be such a bad idea. Maybe a dot of dielectric grease on the terminals beforehand?
Having some extra butyl myself, used some on my Bug where the throttle, clutch etc. tubes enter the center tunnel. Worked great.
brant
post Mar 28 2025, 02:22 PM
Try the chemical De-oxit
It’s a great electrical product
flxzcat
post Mar 28 2025, 02:31 PM
check temperature rating?
Literati914
post Mar 28 2025, 04:49 PM
QUOTE(brant @ Mar 28 2025, 03:22 PM) *
I actually have some left over from cleaning up my vintage Marantz receiver.. but since my 914 is basically newly rebuilt and grounds are clean - I'm thinking the butyl would keep you from needing to (ever?) clean the connections again.
QUOTE(flxzcat @ Mar 28 2025, 03:31 PM) *
A quick search says -40f to 300f.
JeffBowlsby
post Mar 29 2025, 09:21 AM
NOT a fan of dielectic grease on automotive electrical connections. It attracts dirt and the only remedy is the disassemble and thoroughly clean.
As for the butyl tape idea, I would think it would be difficult to conform to make an air/water tight condition. Butyl theoretically never hardens (it does with a enough time and heat) and its butyl. Ever tried cleaning that stuff up?
Maybe consider brushing on a potting compound, but the cleanup would be insane if it ever needed servicing.
The butyl concept is interesting but the approach may have questionable results. Probably better to resort to the traditional maintenance method of periodically wire brush and chemical clean (DeOxit).
JmuRiz
post Mar 29 2025, 08:53 PM
Good idea on the deoxit, I got some for refurbishing Halloween
decorations and my dad’s old stereo equipment too. I have a bad ground on a PO’s fender repair.
I think they were mentioning butyl caulk over a properly cleaned/grounded connection. I think for how rarely our cars are driven/parked in the rain, it might. It be necessary.
euro911
post Mar 29 2025, 09:11 PM
Try brushing on 'Liquid Tape' It works great
https://www.homedepot.com/p/Gardner-Bender-...B-400/100119178
- Lo-Fi Version Time is now: 2nd April 2026 - 06:27 AM
