| kenshapiro2002 |
Nov 27 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
| Steve |
Nov 27 2025, 05:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,028 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Check out the phase sight for examples.
https://www.pbase.com/9146gt/9146gt_front_m..._oil_cooler_no1 |
| kenshapiro2002 |
Nov 27 2025, 06:28 PM
Check out the phase sight for examples. https://www.pbase.com/9146gt/9146gt_front_m..._oil_cooler_no1 Cool site… thanks. Didn’tsee what I wanted relative to this querie though. |
| mepstein |
Nov 27 2025, 06:39 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,586 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A magnet strip glued to the shroud may accomplish what you are looking for.
Another alternative may be gluing a nut onto the floor so you can screw into it without drilling a hole. |
| kenshapiro2002 |
Nov 27 2025, 06:41 PM
| Cairo94507 |
Nov 28 2025, 10:40 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I bit the bullet and we installed riv-nuts; the shroud is aluminum and not going anywhere. (IMG:style_emoticons/default/beerchug.gif)
| mepstein |
Nov 28 2025, 10:54 AM
You are cutting a big rectangular hole in the floor so how bad can it be to drop in some riv nuts or similar.
I’m building a big metal box that will be welded in but have a removable access panel for the cooler and a/c condenser. It won’t look at all like the GT piece but I don’t really care as long as it looks nice. I feel like the fiberglass shroud is more of a race piece than how I plan to use the car. |
| Montreal914 |
Nov 28 2025, 11:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,071 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
I’m building a big metal box that will be welded in but have a removable access panel for the cooler and a/c condenser. It won’t look at all like the GT piece but I don’t really care as long as it looks nice. I feel like the fiberglass shroud is more of a race piece than how I plan to use the car. @mepstein Now you have my attention... A/C condenser and oil cooler. Hope you will share this in another thread. (IMG:style_emoticons/default/popcorn[1].gif) |
| mepstein |
Nov 28 2025, 11:09 AM
I’m building a big metal box that will be welded in but have a removable access panel for the cooler and a/c condenser. It won’t look at all like the GT piece but I don’t really care as long as it looks nice. I feel like the fiberglass shroud is more of a race piece than how I plan to use the car. @mepstein Now you have my attention... A/C condenser and oil cooler. Hope you will share this in another thread. (IMG:style_emoticons/default/popcorn[1].gif) Sure but for right now, I'm adding electric a/c with a Classic Retrofit kit. Basically copying from @Steve |
| tygaboy |
Nov 28 2025, 12:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,803 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
I'm with @Cairo94507 Michael. I don't have first-hand experience with the fiberglass shrouds - though two friends are installing them now - but they sure seem to fit poorly.
I vote that if you have the ability (or access to someone who can), fab your own from aluminum, that's the way to go to get the tidiest result. Plus you can say "I made that!". All IMO, of course. |
| mepstein |
Nov 28 2025, 01:16 PM
I'm with @Cairo94507 Michael. I don't have first-hand experience with the fiberglass shrouds - though two friends are installing them now - but they sure seem to fit poorly. I vote that if you have the ability (or access to someone who can), fab your own from aluminum, that's the way to go to get the tidiest result. Plus you can say "I made that!". All IMO, of course. Chris - Your work on Michael's shroud was first class. |
| Steve |
Nov 28 2025, 01:32 PM
@kenshapiro2002 Check out my blog for how I did it.
http://www.914world.com/bbs2/index.php?aut...blogid=259& I also used Patrick Motorsports leuvered bottom versus a big hole. Factory was two pieces. A bottom piece to help with air flow and the shroud. I bought mine from Getty Design. I needed a bigger cooler for my 3.6 and AC condenser, so eventually made my own shroud. https://gettydesign.com/category/914/coachwork/ I roughly just laid the shroud down, pencilled around it and cut a half inch to one inch in. Pretty obvious where to cut if you have both pieces. |
| Cairo94507 |
Nov 28 2025, 01:35 PM
I'm with @Cairo94507 Michael. I don't have first-hand experience with the fiberglass shrouds - though two friends are installing them now - but they sure seem to fit poorly. I vote that if you have the ability (or access to someone who can), fab your own from aluminum, that's the way to go to get the tidiest result. Plus you can say "I made that!". All IMO, of course. Chris - Your work on Michael's shroud was first class. Absolutely! We all know Chris' work is beyond beautiful. (IMG:style_emoticons/default/beerchug.gif) |
| Maltese Falcon |
Nov 28 2025, 04:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Lo-Fi Version | Time is now: 1st April 2026 - 06:05 PM |
