| chmillman |
Dec 3 2025, 05:47 AM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Mine are all crushed, and in any case it looks like they weren't the original ones. I'm not going to be ordering them from AA obviously, so I will probably need to make my own. Anyone have the proper dimensions? Looks like the ones I took off were made from slicing something like rubber (fuel?) hose, which is what I might try if I find more or less the right diameter/thickness. ID is probably 6mm. TIA
| mepstein |
Dec 3 2025, 06:07 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
LOL! I can absolutely imagine ordering them from AA and getting some randomly cut pieces of fuel line at $4.77 a piece, $12 handling fee and $20 ship.
| BillC |
Dec 3 2025, 09:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 701 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
914Rubber has them, and probably quite a bit less for the whole set than for each AA piece.
| sixaddict |
Dec 3 2025, 09:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Oops…didn’t see this was from Switzland so deleted irrelevant response.
| cassmcentee |
Dec 3 2025, 09:22 AM
Member ![]() ![]() Group: Members Posts: 243 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California
| chmillman |
Dec 3 2025, 10:07 AM
Well again, ordering from the US is just out of the question because of shipping costs... So fuel hose it is. All I really need is a height. somewhere around 8mm?
| dr914@autoatlanta.com |
Dec 3 2025, 10:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we had a thousand made to precise specifications
Mine are all crushed, and in any case it looks like they weren't the original ones. I'm not going to be ordering them from AA obviously, so I will probably need to make my own. Anyone have the proper dimensions? Looks like the ones I took off were made from slicing something like rubber (fuel?) hose, which is what I might try if I find more or less the right diameter/thickness. ID is probably 6mm. TIA |
| friethmiller |
Dec 3 2025, 11:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,206 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
That decimal needs to slide to the left! (IMG:style_emoticons/default/dry.gif) |
| chmillman |
Dec 3 2025, 12:10 PM
The item pictured on the 914Rubber site looks huge in diameter... If I copy the image and scale it so that the hole is 5mm (a 5mm bolt goes through it) the OD is like 21mm... ![]() AA's image looks more like 16mm |
| porschetub |
Dec 3 2025, 03:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
LOL! I can absolutely imagine ordering them from AA and getting some randomly cut pieces of fuel line at $4.77 a piece, $12 handling fee and $20 ship. (IMG:style_emoticons/default/agree.gif) Yes sadly true ,seems to be the way they roll or bankroll (lol) I would think they lose a lot of business for that reason ? I have a packet of genuine ones part 914-559-127-10 ,got them from Stoddard a long time ago ,they are a hard rubber ,almost plastic like. 15 mm x 7 mm ,the centre hole is 4.5 mm so they are a tight fit with a 5mm bolt which makes sense as it holds them in place, cheers. |
| chmillman |
Dec 3 2025, 03:13 PM
I have a packet of genuine ones part 914-559-127-10 ,got them from Stoddard a long time ago ,they are a hard rubber ,almost plastic like. 15 mm x 7 mm ,the centre hole is 4.5 mm so they are a tight fit with a 5mm bolt which makes sense as it holds them in place, cheers. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/beerchug.gif) |
| johnhora |
Dec 3 2025, 04:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
| chmillman |
Dec 4 2025, 11:12 AM
So I went the sliced fuel hose route for now, until I can find something better.
They aren't absolutely perfectly even - they would have been if the bit of hose I had was straight, but unfortunately it had a slight bend to it - but they're rubber and will compress anyway. 6mm ID, 13mm OD. I went with a 7.5mm target height. It was a $0, right-now solution which seems to work fine. |
| worn |
Dec 7 2025, 06:30 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
So I went the sliced fuel hose route for now, until I can find something better. They aren't absolutely perfectly even - they would have been if the bit of hose I had was straight, but unfortunately it had a slight bend to it - but they're rubber and will compress anyway. 6mm ID, 13mm OD. I went with a 7.5mm target height. It was a $0, right-now solution which seems to work fine. I really love the da to knife clamped into the tool holder. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:04 AM |
