| doug_b_928 |
Dec 12 2025, 06:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
The screws for my fog light grills were the long flat head ones pictured below. PET says that the correct screws are 3.5 x 13, which are the short ones pictured below. All 8 on my car were like the long one. Based on my experience with this car, if all 8 screws are the same then they probably were the original screws (POs were clearly too frugal to change all 8 just to be consistent). So, for those that know what was original, are the long ones correct?
| Dlee6205 |
Dec 12 2025, 06:52 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
The long ones are not correct. I would trust PET
| Jamie |
Dec 12 2025, 07:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,201 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
The screws for my fog light grills were the long flat head ones pictured below. PET says that the correct screws are 3.5 x 13, which are the short ones pictured below. All 8 on my car were like the long one. Based on my experience with this car, if all 8 screws are the same then they probably were the original screws (POs were clearly too frugal to change all 8 just to be consistent). So, for those that know what was original, are the long ones correct? ![]() ![]() Long ones are wood screws, not correct originals. My 73 has Phillips pan head stainless about the same length as your other one, and I replaced the original rusty body clips with plastic expanding anchor "plugs" that fit perfectly in the original body holes, and won't rust. |
| dtmehall |
Dec 12 2025, 07:07 PM
Member ![]() ![]() Group: Members Posts: 261 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| doug_b_928 |
Dec 12 2025, 07:21 PM
Wow, I'm surprised and glad I asked! Thanks for the replies guys.
| dtmehall |
Dec 12 2025, 07:45 PM
make sure that you have the speed nuts in the bumper for the screw to go into
P/N N90048801 |
| TRP |
Dec 12 2025, 08:07 PM
Member ![]() ![]() Group: Members Posts: 280 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
For those of us who are relatively new, what's the PET?
Ted |
| dtmehall |
Dec 12 2025, 08:16 PM
i must confess, i had to look it up. i am working from an old several inch thick book
here ya go for the definition PorscheĀ® Parts Diagrams (PET) |
| JeffBowlsby |
Dec 12 2025, 08:58 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
You can download editions of PET here: https://bowlsby.net/914/Classic/TechNotebook.htm
| Garland |
Dec 13 2025, 12:01 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Harbor freight has a box with workable hardware.
| chmillman |
Dec 13 2025, 01:05 AM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
For those of us who are relatively new, what's the PET? Ted The acronym is actually German. Porsche Ersatz Teile. Literally translated Porsche Replacement Parts. Although in reality, Ersatzteile should be one word, not two. As far as the screws in the OP's post, I just replaced mine a few days ago. The size looked correct, I'm not sure if the originals were stainless or not, but the ones in mine were badly oxidized silver zinc. I replaced them with stainless. They were 3.5mm x 16 sheet metal screws (the sheet metal nuts in the bumper were OK). In the US I think that is the equivalent of a #6 x 5/8" sheet metal screw. |
| TRP |
Dec 13 2025, 12:19 PM
For those of us who are relatively new, what's the PET? Ted The acronym is actually German. Porsche Ersatz Teile. Literally translated Porsche Replacement Parts. Although in reality, Ersatzteile should be one word, not two. As far as the screws in the OP's post, I just replaced mine a few days ago. The size looked correct, I'm not sure if the originals were stainless or not, but the ones in mine were badly oxidized silver zinc. I replaced them with stainless. They were 3.5mm x 16 sheet metal screws (the sheet metal nuts in the bumper were OK). In the US I think that is the equivalent of a #6 x 5/8" sheet metal screw. Thank you. I spent the last 5 years toying around with my classic vette where I had to learn a bunch of acronyms, I thought PET was some sort of Assembly Instruction Manual (AIM) or NCRS type restoration society/standard (NCRS). |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:27 AM |
