| tat2dphreak |
Jul 13 2005, 05:19 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
DUH! (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) this is painfully obvious by this thread... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
| Brad Roberts |
Jul 13 2005, 08:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Cool.
Yes. I have/had jigs/fixtures for a 5 inch round chrome moly control arm using a 911SC wheel bearing. Just like the ones on Roger Sheridans car. B |
| Verruckt |
Jul 14 2005, 05:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
So when are these going to be available for sale, and how much? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
| redshift |
Jul 14 2005, 06:08 AM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Unreal work, fantastic!
M |
| RON S. |
Jul 14 2005, 07:42 AM
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I think your kicking some serious butt on this issue. Since I work in a fab/machine shop,I've entertained the idea of making a prototype set for my car. However,I've been leaning towards doing them out of full titanium. I couldn't see making the necessary fixturing for a trailing arm set,unless the final product reduced some serious unsprung weight. I've used a place out Michigan,Tico Titanium for several parts Ive' designed and lasered out for my 6r,so I know it's cost versus weight trade off.Cost is currently about 15.00 a lb. However,all that being said,if you've already done all the hard work,and all your jig measurements are correct,you may wanna think about capitalizing offa your efforts. Maybe professionalize a drawing for your jig to sell,or maybe out right sell jigs to others. I know I'd be interested in drawing plans. Drawings would take the guesswork outa the whole setup. Way to go. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Ron |
| andys |
Jul 14 2005, 10:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Brad, Are these the one's you're speaking of? Hope the file size is not too large........... Andy Attached File(s)
Tubular_Trail_Arms.doc ( 94k )
Number of downloads: 160 |
| andys |
Jul 14 2005, 10:51 AM
Hmmm, file format problem.......Anyway, they are the assembly three large tubes with a provision for camber adjustment, right?
Andy |
| andys |
Jul 14 2005, 12:03 PM
Ron, Titanium should be a viable alternative from a material properties perspective, but the costs would be quite high. Using your $15/lb pricing, the billet for the bearing carriers alone would cost about $360. The weight advantage of titanium over steel is not huge (about 60% the weight of steel), and depending on which alloy you choose you may find you need added thickness to get the strength (when comparing like designs). Ti CP grade I, has a tensile of anbout 35ksi. CRS (cold rolled steel) is about 60ksi. You'd have to go to Grade III to get comparable properties, and that would likely drive the cost up even more. Do you have the price for Grade III? I suppose if you want to spend the money for your personal project, then that is certainly your decision. Sure would look zippy if they were polished. Have you checked on welding? From past experience, few weld shops have adequate Ti welding experience, but that is not an issue if you hold that particular skill. I have experience with EB and Laser welding Ti, but have never TIG welded Ti myself. Like aluminum, Ti has a high CTE, so you'll have to pay real close attention during welding, as things will move around a lot. For titanium money, I might be inclined (maybe) to go with aluminum for even greater weight savings (about 30% the weight of steel) and use those dollars for *proper post weld treatment*. I don't know if I want to put in the effort to make proper detailed drawings of my weld fixture at this time. It would be pretty time consuming. These arms are for a street application, and have durability and adequacey as a focus. If I were doing a track car suspension, I think would have approached the design a lot differently. Here's a simple basic guide for design considerations with useful links to freeware: http://www.gmecca.com/byorc/designstrategies.html BTW guys, I appreciate the comments. Andy |
| Mueller |
Jul 14 2005, 12:51 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Your trailing arms look good Andy....I'm too much of a hack to show pictures of anything I've done, hence the piss-poor camera phone to mask my butchery (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Correct on those tube weldments, the biggest change is making them a true trailing arm instead of semi-trailing like the stock 914 is....not an easy task on a bone stock 914....I know someone on this site was supposed to be building a 914 race car with relocated mounting mounts (not just "up", but so that the axle is perp. to the chassis centerline) Have you seen Armandos 914/6 GT buildup?? His rear trailing arms are pretty trick, just a few hours worth of work put into them (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Rear trailing arms with spherical bearings Now you are going to powdercoat your new trailing arms correct??? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| andys |
Sep 12 2005, 12:31 PM
The latest pic's to update my progress. The trailing arms are assembled, but not placed on the car. That will follow sometime later when I fit the flares to the (wider) wheels.
Bottom view of left side: Andys Attached image(s)
| andys |
Sep 12 2005, 12:34 PM
Don't ask me why I chose blue. It photographs better than black.
Close of bottom left. Andys Attached image(s)
| andys |
Sep 12 2005, 12:37 PM
Wilwood mechanical spot caliper. I designed the parking brake cable bulkhead and the hydraulic brake line bulkhead to pick up the stock locations, thus the stock connections.
Close of parking brake: Andys Attached image(s)
| TravisNeff |
Sep 12 2005, 12:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
That is trick!
| tat2dphreak |
Sep 12 2005, 12:41 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) those look amazing!
| andys |
BTW, the heavy P-brake return spring is a must, otherwise the cable will not properly extend and the P-brake pads will drag.
Andys |
| Aaron Cox |
Sep 12 2005, 01:29 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
| Andyrew |
Sep 12 2005, 02:03 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
when are they going in production!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Cool beans!!!!! |
| 914MF |
Sep 12 2005, 02:35 PM
Member ![]() ![]() Group: Benefactors Posts: 176 Joined: 4-September 03 From: Denver, CO Member No.: 1,112 |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) Those are awesome!!!!!!!!
| Britain Smith |
Sep 12 2005, 03:52 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Those look awesome.
However, what is the advantage of your design? Maybe I missed something, but you still don't have a method to adjust rear camber with this set-up. Just wondering. -Britain |
| Aaron Cox |
Sep 12 2005, 04:08 PM
bigger bearings was one thing noted, along with late model hubs to facilitate beefier axle install. He also stated that he could "BUILD" up to 3 degrees of camber in to them, but to adjust, you still require shims like stock |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:05 AM |
