> Symptons of a Bad MPS ?, How can I test?
vesnyder
post Sep 1 2006, 12:57 PM
I am getting terrible milage (~18) in a D-jet 1.7, and individuals have suggested the MPS? Are there other symptons? How can I test? Anybody have a spare I can test?
drewvw
post Sep 1 2006, 01:01 PM
new england car guy
first thing you can do is disconnect and plug the vaccum hose going to it and see if the car runs any different. If the MPS was messed up, chances are performance change would be noticable as well unless its just starting to go.
after that...you have to do the vaccuum pump bit which I'm not very knowledgable about, never had to do that. I think you have to pump it up no more than 15 in and it has to hold for awhile...
search the archives for specifics.
type47
post Sep 1 2006, 01:06 PM
Viermeister
checks are to see if it holds a vacuum for "awhile" and electrical resistance between terminals. exact values i don't know.
Rand
post Sep 1 2006, 01:08 PM
Cross Member
The simple sure-fire test of the most likely MPS failure (bad diaphragm) is to just pull a vacuum on it and see if will hold.
A mityvac is worth buying. Handy tool to have around for other uses too.
drewvw
post Sep 1 2006, 01:10 PM
new england car guy
You Want To Become Very Familar With This Site
jk76.914
post Sep 1 2006, 01:19 PM
1. see if it will hold a vacuum.
2. measure resistance- between outer pins on connector- 90 ohms (about)
3. resistance between the two center pins- 350 ohms (give or take)
4. resistance between either center pin and either outer pin- zero ohms.
5. resistance between either center pin and ground- zero ohms.
6. resistance between either outer pin and ground- zero ohms.
There's a good chance it won't hold a vacuum with those MPG numbers. If the diaphram is leaking, it'll fool the MPS into thinking, "hmmmm. He must be running WOT. I guess I'll richen up the mixture for him!"
If all these tests are OK, the MPS could still be bad. But you'd need an LC meter to go to the next step of testing.
Jim
SLITS
post Sep 1 2006, 01:39 PM
"This Utah shit is HARSH!"
After you've done the MPS thingy.....
1.) Fuel Pressure ... high pressure can override solenoid in injector....turns it into a constant injection
2.) Valve adjust
3.) timing
etc......,
vesnyder
post Sep 1 2006, 02:37 PM
Used my trusty MityVac to check the vacuum and it does not hold, as you suspected Jim! Now what? Can they be repaired? If not, what is a good source? I see at Pelican they are NLA? How successful have guys been buying used one?
drewvw
post Sep 1 2006, 02:38 PM
new england car guy
bleyseng is the man...talk to him
Bleyseng
post Sep 1 2006, 05:16 PM
Aircooled Baby!
I think I have sold about 40 rebuilt ones to club members. 037's, 043's and 049's.
just trying to keep em on the road with a REAL MPS calibrated to spec so you get a good drive.
I don't use silicone, duct tape or solder to repair diaphrams...
type47
post Sep 1 2006, 06:20 PM
Viermeister
let's say someone had an LM-1. how do you adjust an MPS? not interested in the steps, just theory, what you're trying to do... i have an MPS with a small hole drilled to access a tiny screw under the outer cover screw. i bought it that way not really knowing about the hole.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:11 AM
