| lincoln |
Sep 10 2006, 02:49 AM
Member ![]() ![]() Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None |
think ive decided on getting the largest size typeIV i can to build for the car, am also planning on a pertronix? billet alum distributor with ignitor II , and am looking at a set of brosol/solex carbs in either 40s or 44s , cept the carbs i found say they are for a type 1 dual port , but they come with all the hardware manifolds etc for what id say was a reasonable price of bout $430 for the 40s and $499 for the 44s.this is for brand new, not remanufactured.
would these work? |
| JPB |
Sep 10 2006, 05:24 AM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Go for it bro. If you can, get your kit from Raby, he has a 20% off on two engine kits; the 2056 & 2270. The sale is ending Feb. 13 on wednesday this coming week!!! He's got a 2270 stroker kit which will make some good HPs for the same price as the standard 2270 which is for about 150HPs. If your ready to get a rebuild kit, September is the time to do it!!
(IMG:style_emoticons/default/beer.gif) Gluck. |
| ejm |
Sep 10 2006, 05:39 AM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,716 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
sorry but type 1 manifolds won't fit a type 4
| lincoln |
Sep 10 2006, 06:34 AM
so a 2270 stroker hm? good to know on the manifold thing cuz pics i saw looked just like the ones for type 4s, but pics were really small so maybe i just couldnt tell that well were in a jcwhitney cat for vw stuff dist says its a direct replace for the 009 so im guessing thats good? |
| davep |
Sep 10 2006, 06:48 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
directly replaces a 009 does it? And how good are 009's? Do they pass the float test? Are you building a water pump or a car here?
| So.Cal.914 |
Sep 10 2006, 12:31 PM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
directly replaces a 009 does it? And how good are 009's? Do they pass the float test? Are you building a water pump or a car here? I am not sure exactly what this means ^^ but if you can afford it you don't want to cheap out on your dizzy or your carbs for that matter. I could suggest brand names but I think you should check out the search funtion and read what has been proven to be funtional, durable and performance inhancing. |
| lincoln |
Sep 10 2006, 04:30 PM
well jake in his show said that pertronix was better than the bosch 009 and its cnc machined to pretty tight tolerances with a +0.00 to -0.003 . almost as good as the MSD one and at bout 200 bucks i wouldnt call it exactly cheap ( dist)
carbs now, im still looking into those more and ill also look a bit more into distributors but so far these seemed to be good as far as quality/pricing links carbs http://www.jcwhitney.com/autoparts/Product...0005279/c-10110 dist http://www.jcwhitney.com/autoparts/Product...0004547/c-10110 |
| So.Cal.914 |
Sep 10 2006, 05:02 PM
well jake in his show said that pertronix was better than the bosch 009 and its cnc machined to pretty tight tolerances with a +0.00 to -0.003 . almost as good as the MSD one and at bout 200 bucks i wouldnt call it exactly cheap ( dist) carbs now, im still looking into those more and ill also look a bit more into distributors Just about anything is better than the 009. Cheap is relative. In the classifieds here there is a used set of 40 IDF's with manifolds, linkage and air filters for.... I think it was $375.00. Rebuild kits are inexpensive. |
| davep |
Sep 10 2006, 06:10 PM
| Jake Raby |
Sep 11 2006, 07:44 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The 009 was developed for Porsche 912/616 race engines.
BTW- My special is only for Radio Show listeners. If I believe that a purchaser has not listened to the show they will be given a test about radio show content before the order will be initiated. |
| bd1308 |
Sep 11 2006, 08:01 AM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
Sweet! So apparently the Ljet distributor is a race dizzy with a cav advance pot?
Cool! |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:19 PM |
