| Gint |
Mar 26 2007, 07:32 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I had half a dozen titles for this thread in my head... It's finally time to mount the Superlite wheels I bought in June 06. Mike Z was given a second chance offer from ebay when the auction didn't make reserve. He offered them up and I grabbed it. I bought them significantly cheaper than Pack Racing currently offers them for on their website. So it was worth it. Here's the original thread There were many questions (and even a little mis-information) in that thread. I'll answer quite a few here since I now have the wheels have tires mounted on them and I'm about to use them. BTW - 914world member Nick Mironov has a thread about his Superlite wheels. Nick's superlite wheel thread . Nick, you want to read this thread and possibly talk to Pack Racing about a set of inserts with a proper conical lug bolt/nut seat. ![]() This post has been edited by Gint: Jan 2 2013, 06:26 PM |
| Gint |
Mar 26 2007, 08:42 PM
I thought I was getting 2 wheels with 25mm+ offset and 2 wheels with 35mm+ offset. There was a little communication trouble because I was communicating to Pack Racing via Mike Z since it was he who received the second chance offer when the wheel didn't make reserve on ebay. Looking at the wheels, one of them is stamped 12p or 12mm+ offset and the other three are stamped 25p. And it would appear that these were all stamped 12p at one time and stamped over with 25p. Regardless, I measured them all and they are all 25mm+ offset.
I never doubted Herr Mueller as he has done a lot of work with non-factory wheels on 914s, but I now can confirm [/size]what Mike has always said. As has pointed out in the past, 35mm would be a offset for a 914 to use a 205 tire. Seeing is believing! At this point I'll note that Pack Racing doesn't seem to offer a 15x7 wheel with a 35mm+ offset. They have 16x7's in 35mm+ offset but not 15's. Tires... I've now gone from running the fattest tire you can squeeze on a factory Fuchs wheel to the skinniest tire you can fit on a 7" rim. (IMG:style_emoticons/default/laugh.gif) I measured a few 205/50VR15 tires and needless to say they are all different.
I finally ordered 195/55VR15 in the BFG G-force Sport because the thread width and overall width are still as wide or wider than many other 205/50 tires. It looks like they will just barely work out. I have about 1/16" clearance on the outside and 3/4" on the inside. An extra 5mm positive offset from a 30mm+ offset wheel like the factory Fuchs would center it almost perfectly. Or a 35+mm offset wheel like Superlite's 16" could at least utilize a 5mm spacer to achieve optimal clearance on both sides. There may be a tiny bit of fender rolling in my immediate future. (IMG:style_emoticons/default/wink.gif) This post has been edited by Gint: Jun 4 2008, 08:04 AM |
| Aaron Cox |
Mar 26 2007, 08:50 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
let me interject a little. offset is a pretty useless number, as it varies by width....
Backspacing is constant. backspacing is from the inner lip of the wheel to the mounting face. on a 914, you want between 112-120mm backspacing. every fuch wheel has almost the same backspacing even though the width changes. pretty cool. so if you know the max back spacing you can run on your car (before wheel hits inner fender well) You can then pick a custom wheel to fit your car in ANY width you would like. just easier to calculate IMO, those look so sick on your car gint! |
| Gint |
Mar 26 2007, 08:52 PM
Now, this is a piece of info that anyone wishing to order Superlite wheels for a 914 needs to be aware of. Be certain that you tell them that you are purchasing wheels for us on a Porsche 914, (and provided your car is a stock configuration) it uses 14x15mm lug bolts, a 4x130 bolt circle and the hubs are not hubcentric. This should be enough information for them to know what type of insert to install in the wheels prior to shipment. I believe they have not yet supplied many of these wheels for a 914, so they are working out some kinks.
On to the details... Apparently, Pack Racing modifies these wheels and adds inserts into the mounting holes to provide the correct size lug bolt/stud hole and a conical seat. The bolt hole is 17mm, so a 14x1.5 lug bolt or stud will float in the hole. And since these wheels are lugcentric, there is no way without these inserts (or a reasonable substitute) to locate or center the wheel. I'll spare you the long story, but with the help of Terry from Pack Racing, we figured out that these wheels had shipped without the inserts. I'm going to either get a set of these inserts from Terry or make some of my own. I haven't really decided yet. If P.R. will send me the inserts for free I'll liekly go ahead and get a full set. I'll update this thread when that's been determined. The lug bolt/nut mating surface as supplied from the manufacturer is flat. ![]() Close up ![]() Insert rear view ![]() Insert front view ![]() This post has been edited by Gint: Mar 28 2007, 10:29 PM |
| Gint |
Mar 26 2007, 08:58 PM
let me interject a little. offset is a pretty useless number, as it varies by width.... Backspacing is constant. backspacing is from the inner lip of the wheel to the mounting face. on a 914, you want between 112-120mm backspacing. every fuch wheel has almost the same backspacing even though the width changes. pretty cool. so if you know the max back spacing you can run on your car (before wheel hits inner fender well) You can then pick a custom wheel to fit your car in ANY width you would like. just easier to calculate IMO, those look so sick on your car gint! Actually, I disagree. Offset in it's simplest form is the distance from the wheel's centerline to the hub mating surface regardless of the wheel's width. And I like to have all of the numbers. I have no issue with calculating the offset in order to know what I'm dealing with. But that's just me... Details: Factory 5.5" 4x130 Fuchs wheel
I cheesed the Fuchs measurements. They have been corrected 3/28/07. Factory 4 lug (4x130 bolt pattern) Fuchs wheel has an positive offset of 39.6mm. Good information about wheel backspace and offset from Yokohama's web site QUOTE High Performance Wheels The following are various high performance wheel measurements that play an important role in determining tire and wheel fitment: Wheel Backspace This is the distance from the back edge of the wheel to the hub mounting surface. To determine the wheel backspace: 1. Position the wheel face down. 2. Lay a straight-edge across the back of the wheel. Measure the distance from the straight-edge to the wheel's hub mounting surface. Wheel Offset The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. The offset of a wheel can be one of three settings: * Zero offset: The hub mounting surface is even with the centerline of the wheel. * Positive offset: The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars. * Negative offset: The hub mounting surface is toward the back or brake side of the wheel's centerline. "Deep dish" wheels are typically negative offset. Offset can be calculated by positioning the wheel on a flat surface and measuring its overall width and backspace as shown below. Divide the overall width by two, then subtract this result from the backspace value. Offset = Backspace - (Rim Width รท 2) ![]() Here's a drawing from Fikse that I especially like. QUOTE ![]() This post has been edited by Gint: Mar 28 2007, 10:57 PM |
| nebreitling |
Mar 26 2007, 10:09 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
Hoosiers are 8.7" across! |
| Gint |
Mar 26 2007, 10:11 PM
Hoosiers are 8.7" across! There's one in every crowd! (IMG:style_emoticons/default/laugh.gif) I'll modify that bit of text. Street tires... ![]() |
| Joe Ricard |
Mar 27 2007, 02:10 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
QUOTE Hoosiers are 8.7" across! Hmm My Hoosiers are 11" across. with a tread compound of 25. (IMG:style_emoticons/default/blink.gif) and with 4.5" of backspace they Just freaking barely rub the inner fenderwell and I can nearly get my pinky finger between the outer flared fender lip and tire. |
| Tobra |
Mar 27 2007, 09:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
More tires in 195-55-15 than you would think;
nice wheels, pretty green car |
| Borderline |
Mar 27 2007, 11:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
How much do these "superlite" wheels weigh??? They look gud! OK just looked it up.
they weigh about 18.9 lbs! Not exactly super lite. |
| sean_v8_914 |
Mar 28 2007, 01:18 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
vcb
| Gint |
Mar 28 2007, 08:43 AM
How much do these "superlite" wheels weigh??? They look gud! OK just looked it up. they weigh about 18.9 lbs! Not exactly super lite. Weight wasn't a major factor for me. This is a street car. I just wanted something different and these wheels certainly provide that! |
| sk8kat1 |
Mar 28 2007, 11:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
I really like those!! so what is the proper wheel size ( bolt spacing ... back spacing , offset... 15x ?? ) for a 914 then ?! I have 4 lug fuchs and would like a direct replacement for them and so could I swap my 195-50-15 's to them... or another size that would work well with the tires I already
| Gint |
Mar 28 2007, 11:39 AM
Mine are 15x7 25mm+ offset.
IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page |
| sean_v8_914 |
Mar 28 2007, 11:53 AM
good info about backspacing and offset here
| sk8kat1 |
Mar 28 2007, 11:57 AM
Mine are 15x7 25mm+ offset. IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page ...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along |
| Aaron Cox |
Mar 28 2007, 12:30 PM
Mine are 15x7 25mm+ offset. IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page ...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... |
| Gint |
Mar 28 2007, 12:36 PM
...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... (IMG:style_emoticons/default/blink.gif) They aren't *that* custom Aaron. They only have a few sizes and they don't offer a 15" in 30 or 35 offset. |
| Aaron Cox |
Mar 28 2007, 12:40 PM
...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... (IMG:style_emoticons/default/blink.gif) They aren't *that* custom Aaron. They only have a few sizes and they don't offer a 15" in 30 or 35 offset. preaching to the choir.... i KNOW that. did you require a spacer? nope. use a 23mm or your 25mm if thats all they make it in. im advocating doing the homework and research (find out what your camber is and how far inboard you can go to dictate offset and backspacing...) |
| sk8kat1 |
Mar 28 2007, 12:50 PM
arron if you are trying to make me do my " homework " then say so .. but I already know that I am lacking in that area knowlage wise and that is why I asked ... not to pawn off on the folks that post here . (IMG:style_emoticons/default/dry.gif) yea I took the short cut to get to the best set up as a starting point and freely admitted to my taking that short cut .
gint thanks for the info (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:53 PM |
