> Idle Control Screw on ECM, Do I have one?
customstarr
post May 23 2007, 08:46 PM
King of the Nighttime World
From: Waterford, Michigan - Home of Waterford Hills Road Racing
1971 914/4 1.7 with DJET - question is, does this year have the idle contol adjustment pot/screw on/near the ECM? If so, where's it located? I've been trying to fine tune and methodically work out some idle issues. I thought it would be good to know the status on that as I moved forward.
Obviously, I know where the ECM is - I've just never seen that adjustment feature in the near vacinity.
Thanks.
ptravnic
post May 23 2007, 08:49 PM
I could try to describe it but it is best explained here:
http://members.rennlist.com/pbanders/ecu.htm
Happy reading!
-pt
Bleyseng
post May 23 2007, 08:52 PM
Aircooled Baby!
I don't think the 71 1.7L ECU had the idle mix screw. (IMG:style_emoticons/default/dry.gif)
drgchapman
post May 23 2007, 09:17 PM
Current Stable
Group: NoClassifiedAccess
QUOTE(Bleyseng @ May 23 2007, 07:52 PM) *
My '73 2.0 has one. Car runs best with it turned all the way to the right.
'73 may have been the first or only year, I'm not sure which. I do know the MPS and CHT are unique tot he '73 2.0.
drewvw
post May 23 2007, 09:34 PM
new england car guy
1.7 idle knob ECUs probably started sometime in 72.
if you pull the ECU you'll know if you got it or not. Grey knob on one of the long skinny sides that goes 22 clicks....
TravisNeff
post May 24 2007, 11:53 AM
1972 definately has the idle mixture knob
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 AM
