| AvalonFal |
Jan 5 2008, 10:11 PM
Member ![]() ![]() Group: Members Posts: 487 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
A few wires from a couple of my 74's multi-wire plastic connectors have broken off at the connector and I need to crimp on new connectors. I'm looking for the uninsulated 2.8 mm female push-on type with the tang (barb) on the top that secures it into the plastic connector housing. Can't find them locally and several websites have only without the tang. Anybody know a source??
| r_towle |
Jan 5 2008, 10:32 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
show a pic.
Rich |
| sww914 |
Jan 6 2008, 01:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Wurth used to have them, I don't know if they still do.
| type47 |
Jan 6 2008, 08:37 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i found small female spade connectors at Radio Shack
| swl |
Jan 6 2008, 09:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
got some from VW parts dept at local dealership
| Cap'n Krusty |
Jan 6 2008, 10:41 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
How many ya need?
The Cap'n |
| AvalonFal |
Jan 7 2008, 10:14 AM
| anderssj |
Jan 7 2008, 12:12 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,782 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
Volvo dealer usually stock a few of these connectors in the "tackle box" for the techs in the service department; you can also order larger quantities from their parts department. They also have the cool ratchet-type crimping tools for these. You can also get the various plastic connector housings from them. I'll try and post some part numbers later.
| iamchappy |
Jan 7 2008, 12:49 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
| anderssj |
Jan 7 2008, 02:47 PM
Or try susquehana motorsports at:
http://www.rallylights.com/hella/connectors.asp from their site: HL87271 Terminal, 2.8mm (.110") Female Blade Connector with Barb for Relay Blocks, not insulated. $0.24 Hope this helps! |
| AvalonFal |
Jan 7 2008, 03:47 PM
Or try susquehana motorsports at: http://www.rallylights.com/hella/connectors.asp from their site: HL87271 Terminal, 2.8mm (.110") Female Blade Connector with Barb for Relay Blocks, not insulated. $0.24 Hope this helps! I tried this site for the past few days. They list them, but don't have any in stock. |
| AvalonFal |
nm
Lo-Fi Version | Time is now: 2nd April 2026 - 11:57 AM |
