| Vicioso |
Dec 12 2024, 01:06 PM
Newbie ![]() Group: Members Posts: 10 Joined: 2-July 24 From: Prescott Arizona Member No.: 28,214 Region Association: None |
I replaced my fuel injectors on my 2.0 - 4 and the car will not run it seam's like I'm getting fuel any ideas?
| fiacra |
Dec 13 2024, 09:27 AM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 708 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
This is such a common scenario... I did X and then Y happened. For just one example see a recent thread about replacing spark plugs and wires, and then the car not starting. You need to very carefully inspect every area that you worked in. Assuming the car started and ran before you did this, even if it ran poorly, the odds are really high that you knocked something loose or put something back on incorrectly. This is why you take a lot of pictures before touching anything. Speaking of which, post pictures, give some more background information, and you will get some good advice and a path forward. In the above referenced case it turned out the CHT connection was disconnected by accident causing a no-start condition. A posted picture helped an eagle eyed member spot that and solve the problem. So, I'll reiterate, post some good pictures to let everyone see the wiring and how things have been reconnected. And, just for fun, check the CHT connection....
Oh, and follow the excellent advice and answer the questions of the other members who have already chimed in. |
| FlacaProductions |
Dec 13 2024, 09:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Vicioso 914 2.0 injector issues Dec 12 2024, 01:06 PM
rjames
I replaced my fuel injectors on my 2.0 - 4 and th... Dec 12 2024, 02:53 PM
Vicioso
I replaced my fuel injectors on my 2.0 - 4 and t... Dec 13 2024, 11:11 AM
914Sixer Tell us about the replacement injectors, are they ... Dec 12 2024, 05:24 PM
Vicioso
Tell us about the replacement injectors, are they... Dec 13 2024, 11:36 AM
emerygt350 If you turn the key on and actuate the throttle yo... Dec 13 2024, 05:38 AM
rfinegan Does the fuel pump prime on key on or hear it whil... Dec 13 2024, 07:23 AM
Vicioso Yes I sprayed starter fluid and it ran great for a... Dec 13 2024, 11:15 AM
fiacra
Yes I sprayed starter fluid and it ran great for ... Dec 13 2024, 11:52 AM
Vicioso I just checked the box and yes they are Standard F... Dec 13 2024, 11:38 AM
Vicioso Just checked the CHT its fine and yes the car ran ... Dec 13 2024, 12:26 PM
Superhawk996
What does this re... Dec 13 2024, 12:42 PM
JeffBowlsby There is a lot in this text that begs more info:
... Dec 13 2024, 02:21 PM
Vicioso Sorry I work on Motocross bikes way easier. yes I... Dec 13 2024, 04:05 PM
Superhawk996
Sorry I work on Motocross bikes way easier. …
... Dec 13 2024, 05:50 PM
Superhawk996 Also seeing you are new to the site :wttc: Dec 13 2024, 05:53 PM
Puebloswatcop :wttc: Don't give up. These cars can be very... Dec 14 2024, 09:08 AM
Vicioso I agree the car is fun and will be again once this... Dec 14 2024, 10:01 AM
914_teener I'm in Prescott. Let me know if you want my ey... Dec 15 2024, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:30 AM |
