> My car doesnt want to idle no more
magaoidh
post Oct 12 2006, 02:53 AM
Got my '73 2 litre last week and I have been working on rust on the firewall,covered everything up but still got overspray everywhere.
It used to idle slowly, but now it revs fine and dies when I take the foot off the pedal. The gas pedal action is stiff and it is sticking at higher revs, I have to get my foot behind the pedal to flip it back/down.WTF.
I replaced the coil , plug wires,dizzy cao and rotor with some improvement.When the car was ppi'd months ago the low idle speed was noted.Is there an idle adjustment on these cars? What else could it be? Thanks.
Geoff
magaoidh
post Nov 10 2006, 09:24 PM
After a disasterous day Friday, I changed tack on Friday evening and set the timing @27 deg. BTDC with vac advance disconnected and plugged.
This morning I checked the fuel pressure,readjusted the TPS,checked the CHT resistance and said my prayers. Dwell is at 46 deg.
I then drove it around the block turning left all the way,dont forget we drive on the right side of the road??? The right side get it? LOL
Apart from a slight roughness through second the 914 felt good,now I have an idea what its all about.When I got back to my garage it was idling a bit high(thats good I think) so I turned the screw in a touch, now, I wont push my luck but tomorrow........ maybe twice around the block.
magaoidh   My car doesnt want to idle no more   Oct 12 2006, 02:53 AM
mihai914   Hi Geoff, do you have Fi or carbs on the car? Con...   Oct 12 2006, 08:14 AM
Bleyseng   the cable is wrapped around the clutch cable proba...   Oct 12 2006, 08:24 AM
magaoidh   Sorry Fellas, D jet FI.I also replaced the ol...   Oct 12 2006, 04:52 PM
mihai914   Have a look HERE to trouble shoot your idle proble...   Oct 12 2006, 05:29 PM
bd1308   wait, you have stock IGN? .027in is what I set my...   Oct 12 2006, 05:32 PM
mihai914   .7mm = .0275 inch, there's a nice conversion t...   Oct 12 2006, 05:37 PM
magaoidh   Thanks so far,I have just started the car after ad...   Oct 12 2006, 07:07 PM
Bleyseng   Bump up the idle speed to 900rpms and then adjust ...   Oct 12 2006, 07:41 PM
magaoidh   Excuse my ignorance Geoff but how do I bump up the...   Oct 12 2006, 09:17 PM
Bleyseng   On the side of the throttle body is the air bleed...   Oct 12 2006, 10:37 PM
mihai914   Here's a picture with the bleed screw circled ...   Oct 13 2006, 06:45 AM
magaoidh   Bloody hell,I have been off the radar for days bec...   Oct 18 2006, 12:37 AM
fat73
- Lo-Fi Version Time is now: 2nd April 2026 - 12:17 PM
