Spark Plug Heat Range question, Run a hotter plug with dual carbs? To do or not to do? |
UberElectricEagle |
Oct 10 2009, 08:03 PM
atomic Group: Members Posts: 43 Joined: 10-August 09 Member No.: 10,659 Region Association: None |
Hello,
Should I, or May I, use a hotter plug with dual carbs? I have NGK B6ES in there right now. One range hotter would be a B5ES, Right? I seem (or think) to remember with my 67 BSA that NGK gets hotter the lower the number. 1.7 liter with dual weber 34 ICT. 009 dist with regular old points. Many thanks to you. |
UberElectricEagle |
Oct 12 2009, 01:00 AM
A single tear has just rolled down my cheek.
ericread |
Oct 12 2009, 09:37 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Since no one lese has answered, I'll throw in my $.02.
Please note that plug heat range has nothing to do with the voltage that is sent through the plug. Heat range is a measure of the spark plug's ability to remove heat from the combustion chamber, mainly to avoid pre-ignition, which can be disasterous. Pre-Ignition can be defined as ignition of the fuel/air mixture before the pre-set ignition timing mark. This is caused by hot spots in the combustion chamber, which results from advanced ignition timing, a spark plug that is too hot, high compression, low octane fuel, lean air/fuel mix, insufficient engine cooling, or carbon in the combustion chamber. Pre-ignition and detonation are separate events, but pre-ignition frequently leads to detonation Detonation involves rapid, uncontrolled burning of the air/fuel mixture while the piston is still rising. During normal combustion, the flame front propagates across the cylinder at a controlled subsonic speed with the piston near TDC. During detonation, the flame front goes supersonic and/or collides from different directions. This rapid detonation strikes the top of the piston as it is still being pushed upward in the cylinder by the crankshaft. The shock wave resulting when the detonation flame front strikes the top of the piston causes the piston to rattle in the cylinder. The sound of this shock wave and the sound of the rattling piston is what people commonly refer to as ping. Detonation radically increases cylinder pressure and temperature, and can quickly burn the end of the spark plug. Excessive heat is usually what causes engine damage when detonation is ignored. Back to spark Plugs: The heat range is determined by the insulator nose length and its ability to absorb and transfer combustion heat, the gas volume around the insulator nose, and the materials/construction of the center electrode and porcelain insulator. OK, what engine parameters affect the operating temperature of a spark plug? 1. Air/Fuel mixture: Rich mixtures reduce the tip temperature, causing fouling and poor drivability. Lean mixtures increase both tip temperature and combustion chamber pressure, resulting in pre-ignition. It is important to read the spark plugs frequently while tuning after engine modifications, the spark plugs will help you achieve an optimum air/fuel ratio. 2. Compression ratio/forced induction: As effective compression ratio increases through engine modifications or forced induction, a colder plug using a narrower gap and higher ignition voltage is required. 3. Ignition timing: Advancing the ignition timing by 10° increases the plug tip temperature by approx. 70°-100°C. 4. Engine speed and load: Increases in firing-end temperature are proportional to engine speed and load. When consistanly traveling at high engine speeds or hauling, towing, or pushing loads - install a cooler plug. 5. Weather: Temperature, humidity, and barometric pressure all affect air density and intake volume. Higher intake volumes result in leaner mixtures and hotter plug tips. In identical spark plug types, the difference from one heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber. A longer the nose on a spark plug forces the heat from the tip to travel farther before it is absorbed by the cylinder head, which reatins more of the heat in the plug tip - making the plug "hotter" than a similar plug with a shorter nose. Engine temperature will affect a spark plug's operating temperature, but not the plug's heat range. Soooo, what have you changed. I assume in going from FI to dual carbs, you installed a new cam? Has your engine work affected ignition timing, compression, air-fuel mixture? Have you installed a cylinder heat temperature (CHT) guage so that you can see at what temp you engine is running? None of the above really answers your question, but it at least frames some of the issues. Eric Read |
yeahmag |
Oct 12 2009, 11:37 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Long story short, you probably don't need to change the plug temps if you tune the car well. Start with stock temp plugs.
ericread |
Oct 12 2009, 11:44 AM
yeahmag |
Oct 12 2009, 11:46 AM
Actually, you made some great points, just probably not applicable for most of us. I'd love to see your reply set up as a "Classic Thread".
ME733 |
Oct 12 2009, 12:36 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
Actually, you made some great points, just probably not applicable for most of us. I'd love to see your reply set up as a "Classic Thread". (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
UberElectricEagle |
Oct 12 2009, 01:34 PM
Thanks for the reply Eric. Educational and informative.
I usually try not to read that much in one sitting. |
r_towle |
Oct 12 2009, 04:05 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It always amazes me what people know on this site.
I suspect some day long ago Eric had questions and learned all that was known about spark plugs.... Thank you Eric. Rich |
Jeffs9146 |
Oct 12 2009, 04:59 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had a 67 911 that ran rich and seemed to fowl plugs so I ran plugs that were 1 level hotter and it ran like a champ from then on!
ericread |
Oct 12 2009, 05:21 PM
I had a 67 911 that ran rich and seemed to fowl plugs so I ran plugs that were 1 level hotter and it ran like a champ from then on! Manufacturers are often very conservative and usually specify a plug on the cooler side of the heat range. So running one index hotter can make a difference. However, did you ever determine why you were running rich? A comparison might be adding more and more oil rather than fixing the oil leak... Oops, sorry, this is a 914 board; Of course we keep adding oil (IMG:style_emoticons/default/biggrin.gif) Eric |
Jeffs9146 |
Oct 13 2009, 10:09 AM
QUOTE However, did you ever determine why you were running rich? Yes, it was an old 2.0L 6 with old Webbers so it did burn a bit of oil. I leaned out the carbs a bit but is just ran better with hotter plugs and a bit more fuel/air mix! I was planning on putting in a new motor so it was just about how it ran for now! |
Rav914 |
Oct 13 2009, 11:15 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
I had a 67 911 that ran rich and seemed to fowl plugs so I ran plugs that were 1 level hotter and it ran like a champ from then on! Same here ('67S). A car notorious for fouling plugs. Mostly due to overlapping cams. I briefly tried Bosch and they were ruined in one drive. I think I ran NGK BP5ES and that helped a lot. That and a constant high state of tune; valves and timing down to a knat's ass, and keeping RPM's above 3500. |
Jeffs9146 |
Oct 13 2009, 01:05 PM
QUOTE I think I ran NGK BP5ES and that helped a lot. That's exactly what I did! Nothing would run as well as the NGK BP5ES! |
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 PM |
