Calling all tall drivers |
the head |
Oct 13 2009, 12:23 PM
Newbie Group: Members Posts: 16 Joined: 8-October 09 From: des moines ia Member No.: 10,906 Region Association: None |
Hey all I am looking for any information on fitting a taller driver into a 914 anyone over 6' please chime in we are trying to work on necessary fabrication for a race car at the moment.
Thanks |
flipb |
Oct 13 2009, 12:32 PM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Not sure what specific info you're looking for. I'm about 6'2" and I fit pretty well in my 914. In fact, I even moved the seat forward one click to make sure I would always get the clutch pedal all the way to the floor.
I have original stock seats, dash, and steering wheel. I can't "hop in" as quickly as with other cars due to the large wheel, but it's easy enough to squeeze my legs under the wheel. On easy/highway drives, I'll lean my head back and it hits the targa bar. I can drive with the roof on with no problem. But if you're fitting a roll cage, it will probably take a good deal of measuring around your driver. |
carr914 |
Oct 13 2009, 12:43 PM
Racer from Birth Group: Members Posts: 118,556 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) I'm a shade over 6'. On my last track car, I was using a MOMO Nascar seat. The mounts were bolted directly to the floor - worked great.
T.C. |
the head |
Oct 13 2009, 12:46 PM
Our tallest driver is 6'5"
which is where our issue lies the rest of us all are in the 6' or shorter area |
flipb |
Oct 13 2009, 12:48 PM
Our tallest driver is 6'5" which is where our issue lies the rest of us all are in the 6' or shorter area Would a phone book pass tech inspection? (IMG:style_emoticons/default/lol-2.gif) |
the head |
Oct 13 2009, 12:52 PM
we actually have had a memory foam booster made up for our short driver (she is 5'3") I just need assistance with getting everything to line up with getting this guy in below the cage and hopefully the targa car will be used for long races where weather may be an issue adjusting to fit smaller drivers is really easy
URY914 |
Oct 13 2009, 01:01 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,532 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is your seat bolted to the floor or does it have the slide adjuster still in it?
Drums66 |
Oct 13 2009, 01:14 PM
Wilt(the stilt)chamberlain the famous Laker can fit in 1
of these......you should be able to?I think he is at least 7'5......I'm sure someone has a Picture to post?? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Rand |
Oct 13 2009, 01:35 PM
Wilt(the stilt)chamberlain the famous Laker can fit in 1 of these......you should be able to?I think he is at least 7'5......I'm sure someone has a Picture to post?? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) Doesn't look like he fit too well. (IMG:style_emoticons/default/laugh.gif) (IMG:http://www.914world.com/bbs2/uploads/post-3573-1221957352.jpg) |
Gary |
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
If you're doing fab work, you could lower the pan aft of the reinforcement: lowered rear pan.
Drums66 |
Oct 13 2009, 01:47 PM
Hey he looks comfortable at closer to 8 ft.
besides taking away from the roll-bar purpose! (IMG:style_emoticons/default/biggrin.gif) LOL |
ericread |
Oct 13 2009, 01:48 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Actually, "tall" is kind of a misnomer in dealing with this issue. I am 6' 4" and have a pretty normal leg to torso ratio. As such, I have no problems in driving my stock daily driver. A friend of mine, whom is 5' 6" tall, has short legs and a very long torso. As such, although he has no problem with leg room, he actually sits taller than me in the seat, and has difficulty in fitting with teh targa top on.
So you may need to get some mmeasurements to determine the issue you are anticipating. Eric Read |
carr914 |
Oct 13 2009, 02:39 PM
This is a floor extension Bob Snodgrass @ Brumos did for his car.
T.C. |
brant |
Oct 13 2009, 03:06 PM
This is a floor extension Bob Snodgrass @ Brumos did for his car. T.C. that is so not a good idea! I've taken the race car off track over FIA style concrete berms (the red and white stripped ones common to approved race tracks) I've ripped out the submarine strap eyelet that was going through the floor board also ripped and damaged plenty of the floor pan and floor brace I wouldn't recommend a lowered floor pan like that for actual wheel to wheel competition...... maybe a street car |
pcar916 |
Oct 13 2009, 04:07 PM
I'm 6' and use Momo Acropolis seats bolted to narrowed stock seat rails. Even with a helmet there's room to spare.
I drive with the seat most of the way forward for proper ergonomics with the pedal-work, and space the steering wheel close to me to make up for the rest. Cage geometry can force some contortions, so if and when you're ready to install one, spend plenty of time on what it'll do to your position in all directions and the control pattern. Good Luck! |
aircooledtechguy |
Oct 13 2009, 05:42 PM
I'm almost 6'3" and I fit just fine. I gave my father a ride in mine a while back and he's 6'5". He had no problem with room. In fact he commented about how much room it had inside. Getting out, OTOH was a chore for him, but he's 75 so I cut him some slack (IMG:style_emoticons/default/biggrin.gif)
jaminM3 |
Oct 13 2009, 06:03 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I'm 6' 3" and have 2-3" of head room with the top off. My car is completely stock. I think it would be tight with a helmet on....
GeorgeRud |
Oct 13 2009, 09:08 PM
I'm 6' tall, but with a 29 inch inseam, so I have a terrible time with headroom (that's why I only buy open top cars, except my Scion xB office car).
The 914 has an exceptional amount of room, but you can't lean the seat back like you can on most other cars. Realistically, you have to seat the driver's in place and measure carefully. With a rollcage, you will have a hard time with taller drivers (IMHO). |
hot_shoe914 |
Oct 14 2009, 01:46 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I'm 6' and use Momo Acropolis seats bolted to narrowed stock seat rails. Even with a helmet there's room to spare. I drive with the seat most of the way forward for proper ergonomics with the pedal-work, and space the steering wheel close to me to make up for the rest. Cage geometry can force some contortions, so if and when you're ready to install one, spend plenty of time on what it'll do to your position in all directions and the control pattern. Good Luck! What the hell do you know, you can't even keep up with your steering wheel. Last time I saw it, it was hanging on the wall in a Cracker Barrel resturant! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/poke.gif) |
Todd Enlund |
Oct 14 2009, 02:29 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I'm 6' and use Momo Acropolis seats bolted to narrowed stock seat rails. Even with a helmet there's room to spare. I drive with the seat most of the way forward for proper ergonomics with the pedal-work, and space the steering wheel close to me to make up for the rest. Cage geometry can force some contortions, so if and when you're ready to install one, spend plenty of time on what it'll do to your position in all directions and the control pattern. Good Luck! What the hell do you know, you can't even keep up with your steering wheel. Last time I saw it, it was hanging on the wall in a Cracker Barrel resturant! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 09:16 AM |
