Calling all tall drivers |
the head |
Oct 13 2009, 12:23 PM
Newbie Group: Members Posts: 16 Joined: 8-October 09 From: des moines ia Member No.: 10,906 Region Association: None |
Hey all I am looking for any information on fitting a taller driver into a 914 anyone over 6' please chime in we are trying to work on necessary fabrication for a race car at the moment.
Thanks |
JazonJJordan |
Oct 14 2009, 07:13 AM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
I'm 6' and use Momo Acropolis seats bolted to narrowed stock seat rails. Even with a helmet there's room to spare. I drive with the seat most of the way forward for proper ergonomics with the pedal-work, and space the steering wheel close to me to make up for the rest. Cage geometry can force some contortions, so if and when you're ready to install one, spend plenty of time on what it'll do to your position in all directions and the control pattern. Good Luck! What the hell do you know, you can't even keep up with your steering wheel. Last time I saw it, it was hanging on the wall in a Cracker Barrel resturant! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) |
pcar916 |
Oct 14 2009, 08:30 AM
HEY! Just don't get started on me... I'm easily intimidated! (IMG:style_emoticons/default/driving.gif)
the head |
Oct 14 2009, 10:01 AM
This is all very good information guys thanks for all the help so far (judging by the condition of these two derelect 914s I have you may be hearing a lot from me) another question for this is has anyone relocated the shift lever on these cars? I dont know if this is a possibility or not it is just a matter of how much side to side movement the shift rod accepts, or if I will have to make a new one, also any recommendations on short throw shift kits for it?
Scott S |
Oct 14 2009, 10:32 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
I'm 6' tall, but with a 29 inch inseam, so I have a terrible time with headroom (that's why I only buy open top cars, except my Scion xB office car). I am in the same boat – only 6’2”, but with a 30” inseam. I have the Renegade seat with the modified bottom cushion, which is simply a 1” thick piece of upholstered foam. It made the car very comfortable (even with the roof on) and I use the stock steering wheel. However, my helmet still hits. The below pic is magnified by the weird angle and the fact that I have a very heavy coat on – but you get the idea - long torso syndrome stinks. Even on my daily drivers, I cant buy a loaded model, as that always seems to include a sunroof. Attached thumbnail(s) |
carr914 |
Oct 14 2009, 10:33 AM
Racer from Birth Group: Members Posts: 118,774 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
RennShift
the head |
Oct 14 2009, 10:45 AM
anyone recommend a more cost effective unit? factory swap from another car new bushings etc help?
URY914 |
Oct 14 2009, 12:06 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,758 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Why not form a hump in the fiberglass top like Ford did in the top of the Ford GT`for Dan Gurney.
the head |
Oct 14 2009, 12:57 PM
that works for the top but if the car rolls and his head is above the cage I dont think it will fare well
URY914 |
Oct 14 2009, 01:00 PM
So you don't want to lower the floor and you won't raise the roof.
Get a shorter driver. |
Porcharu |
Oct 14 2009, 02:02 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I am only 6' tall but I have a long torso and my head brushes the top, I normally drive (back when I actually drove the car (IMG:style_emoticons/default/dry.gif) ) with the seat cushion removed entirely. I plan on lowering the floor pan about an inch with provisions for hitting stuff. It was pointed out by someone on this board that you really need angles to deflect impacts - especially from the rear, think about a spin and a curb.
Steve |
the head |
Oct 14 2009, 02:05 PM
Actually we are going to lower the floor I had commented that it was the type of thing I was looking for
Oct 14 2009, 05:33 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
loose the front frame piece on the floor in front of the seat.
Replace that with some thicker steel, yet lower to 1/2 inch. Cut around the side, the rear, and the tunnel. Bend the back of the floor down about 1.5 inches. Make up triangles to fill in the sides, and a flat piece for the rear. Then mount the seat directly to the floor, and mount it at an angle...more of an angle than the stock seat, so you are lying down a bit more. Get a smaller steering wheel. For the shifter, If you replace all the bushings with custom bronze ones, especially the firewall (jwest sells a firewall bushing, so does patrick motorsports) you will eliminate some of the slop. You can cut the tunnel and raise the shifter up a bit, then cut the shifter down so its shorter. Rich |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:16 AM |
