Weber IDF Rebuild, Replacing the spindle bearings |
pilothyer |
Oct 13 2009, 06:49 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I have not been able to find any information in any Weber IDF rebuild article that goes into this area.......Has anyone done this that could help me out with a little information or maybe a link to a rebuild article that covers this with some detail? When I removed the spindle and the bearings I noticed a difference in the parts between the two carbs, namely the flat brass pieces that go on either side of the bearings......Thanks in advance for any help.....Jerry
neil30076 |
Oct 13 2009, 07:27 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
pilothyer |
Oct 13 2009, 09:06 PM
Hey, Thanks but that exploded view doesn't show the pieces I am trying to figure out....Jerry
McMark |
Oct 14 2009, 01:13 AM
I tried replacing throttle shaft bushings on a single throat carb (not an IDF) and learned one thing from that experience: it's not a job for most home mechanics. My test run was on a garbage carb, and I don't think I made anything any better after futzing with it for a couple hours.
DBCooper |
Oct 14 2009, 07:38 AM
I've destroyed a few myself over the years, it was always hit or miss. The dismantling was hard, reassembly a lot more difficult and critical. Last two times I sent Dellortos with frozen shafts to Art Thraen in Utah. Beautiful work, about $70-75 each if I remember right, and I think they came back actually better than new. Aircooled Engineering Recommended.
For a good book try the CB Performance Weber book (http://www.cbperformance.com/catalog.asp?ProductID=4) which has exploded diagrams and most any other info you'd want. At $12.95 it's a steal. Or their parts at http://www.cbperformance.com/category.asp?categoryid=6 I think Redline has diagrams online too (http://www.redlineweber.com/html/Tech/Table_of_contents.htm), as does Pierce Manifolds (http://www.piercemanifolds.com/) Love those Pierce guys, they're really great. |
Gint |
Oct 14 2009, 08:16 AM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I messed with a pair of carb throttle shafts and had the same results. In my case they were triples, but the experience applies equally to IDFs. I won't do it again. And I've heard nothing but good things about Art Thraen myself. If I were working on IDFs that's where they would go. |
pilothyer |
Oct 14 2009, 11:58 AM
Thanks one and all for your input......actually the disassembly and reassembly is not the problem (I will admit removing the accelerator pump cam roll pin took some finesse) but I have found a difference in the number of spacers on each side of the bearings in one carburetor when compared to the other one. I have looked at several exploded views but none seem to show much detail in that area...maybe the good Art Thraen could help me with a little "tech support"......Again Thanks. Jerry
Lo-Fi Version | Time is now: 11th May 2024 - 07:46 AM |
