Can you use 911 headers on a mid engine? |
Joe Bob |
Mar 14 2004, 10:35 PM
Don't have a motor around to test fit....but I have a set of headers that could easily weld extensions on....but will they fit bass ackwards? I can take a pic.....
Zeke |
Mar 14 2004, 10:49 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Mike, I have thought about this as I too have some 911 headers laying around here. But when I look at the pics of the Bursch 914/6 setup, the pipes all go in a completley different direction (obviously). The point being if you have to do that much work to the 911 headers, you might as well build a set from scratch using the collectors and the first few inches of the head pipe.
Red-Beard |
Mar 14 2004, 10:57 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Sell them and use the proceeds to buy real 914/6 headers.
Not worth the effort. James |
Joe Bob |
Mar 15 2004, 01:01 AM
So they flanges are bass ackwards? I figured.....thought maybe they just too short but they would fit the other way.....bummer. (IMG:style_emoticons/default/sad.gif)
GWN7 |
Mar 15 2004, 02:22 AM
cut the flanges off...turn the tubes around and reweld the flanges on?
ArtechnikA |
Mar 15 2004, 06:09 AM
just run side pipes like a Corvette ...
Zeke |
Mar 15 2004, 10:03 AM
QUOTE(GWN7 @ Mar 15 2004, 12:22 AM) cut the flanges off...turn the tubes around and reweld the flanges on? Maybe it's worth a try by swapping sides and turning them around. The collectors would be well and truely up under the car leaving a huge distance to any muffler. But let's not let this idean die just yet. Unfortunately, I don't have anything around to try a fit on. I would ask Otto. |
blabla914 |
Mar 15 2004, 11:01 AM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
I'm not sure, but I think you're gonna need to watch the shift linkage. I'm trying to visualize how the 911 boxes would end up swapped, but I don't know the parts that well. Even with the bursch headers the shift linkage is a bit close.
Kelly |
Ferg |
Mar 15 2004, 11:49 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I agree with the sidepipes suggestion (IMG:style_emoticons/default/laugh.gif)
backward sidepipes exiting by the front wheels (IMG:style_emoticons/default/ph34r.gif) |
Zeke |
Mar 15 2004, 12:46 PM
Didn't think of the shift linkage. But, I have been under the 911 and I think by flipping sides and turning backwards the high loop will hit the cam chain covers. That's an easy fix with a u bend from the tubing shop. There are still some issues.
What are we talking about for Bursch? $400? |
J P Stein |
Mar 15 2004, 12:52 PM
I did a test fit of Triad headers on my car at the get together. They give plenty of clearance at the oil cooler feed......something the Bursch don't have (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) ....header wrap.....The Bursch
also come with a lovely coat of black paint that neeeds to be blasted off so a decent coating will stick. They're cheep, tho. Dave needs to do a bit of work on the flanges at the heads...a tad too fat. Other than that, nice. Oil tanks: Quit fuckin' around and do it right. An oil tank is more than a box for oil....baffles, de-aireation(sp?), yada...Otto's (Mikey's favorite)has adaptors....metric to AN...Pegasus too, I think. I have a jig for the shift rod.....which reminds me, I owe one to somebody...gotta get that done. |
Lo-Fi Version | Time is now: 26th May 2024 - 11:12 PM |
