Powder Coating Decel / AAR valves, Could the heat be a problem ? |
jim_hoyland |
Oct 18 2009, 02:12 PM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Will powdercoating a decel valve cause the diaphram inside to distort from the heating process ??
Anyone powdercoated these ? |
zonedoubt |
Oct 18 2009, 02:17 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
I would think there is some sort of elastomer inside the valve. Maybe someone here has taken one apart. Heat from powder coating will probably destroy any soft parts inside. Why take a chance? Why not just paint it?
914Sixer |
Oct 18 2009, 06:41 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just paint it.
jim_hoyland |
Oct 18 2009, 10:12 PM
Just paint it. Painting is definately easier; all the engine tin is powdercoated in silver sparkle and finding a paint to match the powdercoating is difficult. So...I was looking for someone who has tried having them powdercoated (IMG:style_emoticons/default/smile.gif) |
AvalonFal |
Oct 19 2009, 08:44 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
IIRC, doesn't the AAR body act as a ground, so it needs metal contact. Painting or powdercoating it needs to take that into consideration.
Paul |
HeloMech |
Oct 20 2009, 05:45 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
Have you SEEN Jim's car? He doesn't do ANYTHING the easy way... he does it the PRETTY way!!! (IMG:style_emoticons/default/wink.gif)
charliew |
Oct 20 2009, 10:38 PM
It takes 400 degrees to powder coat.
Krieger |
Oct 20 2009, 11:40 PM
Advanced Member Group: Members Posts: 4,706 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Don't f up your part. Unless its just one of those trailer queens.
Lo-Fi Version | Time is now: 10th May 2024 - 10:52 AM |
