Non CW 914/6 oil tank question.... |
Joe Bob |
Mar 15 2004, 09:34 AM
Has anyone used an aftermarket oil tank and mounted it say....in the rear trunk or up front? If so, who made it....?
I'm thinking of doing it because of PRICE, fittings (AN) and better weight distribution.... |
john rogers |
Mar 15 2004, 02:53 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I have the oil tank mounted in the trunk, left side just behind the rear axle shaft. The supply line to the engine is not very long and misses the moving parts under the car well. I did not notice any difference due to the weight moving rearward, but the tank was originally in the right side of the engine compt when the car had a four in it. We did do a rebalance to tilt the car slightly to the right front after all was ssaid and done, but not much was needed. The feed to the front goes through the right side heater duct opening and returns same and goes through the filter then back into the tank. Puke take is in the rear right trunk corner. My tank was originally made by Unique Metal Products in El Cajon CA: http://www.uniquemetalproducts.com/. Good luck
joea9146 |
Mar 16 2004, 05:29 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
www.summitracing.com
has some various sizes you can get some ideas... but there not that cheap 250- 500 |
campbellcj |
Mar 16 2004, 11:21 AM
Seems like the savings wouldn't be that huge after you factor in a Canton remote filter setup (or similar), the extra lines esp. if front-mounted, and so forth (IMG:style_emoticons/default/confused24.gif)
Unless of course you can find a clean used tank for like <$200... |
Joe Bob |
Mar 16 2004, 11:22 AM
Brad says he has one....but......it's Brad and getting him to ship when he's so busy..... (IMG:style_emoticons/default/w00t.gif)
campbellcj |
Mar 16 2004, 11:25 AM
I think your buddy Jim Patrick uses the large Peterson tank also.
You can get metric-to-AN adapters for the engine lines (Pegasus) to run AN- braided instead of the spendy factory ones. (IMG:http://www.nosubstitute.org/events/HSR5Oct02/DSCN0024.jpg) |
Lo-Fi Version | Time is now: 25th May 2024 - 10:53 AM |
