Check Valve in Windshield Washer Lines, What to these things do? |
bobhasissues |
Oct 19 2009, 09:40 AM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Before I tore out my old leaky vacuum pump system, I had little check valves below each washer nozzle. What are these things supposed to do?
underthetire |
Oct 19 2009, 09:51 AM
They keep the fluid from draining back in to the tank. That way the washers worked as soon as you used them.
zonedoubt |
Oct 19 2009, 10:41 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Check valve allows fluid flow only in one direction.
Lo-Fi Version | Time is now: 13th May 2024 - 11:03 AM |
