points, clean up |
points, clean up |
oldschool |
Oct 20 2009, 08:14 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
can i clean the points with contact cleaner?
sorry bad photos btw are the side contact need to have the same gap? Attached image(s) |
oldschool |
Oct 20 2009, 08:24 PM
can i clean the points with contact cleaner? sorry bad photos btw are the side contact need to have the same gap? Attached image(s) |
neil30076 |
Oct 20 2009, 08:35 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
You can clean them with a very light ( 600 grade) emory paper, but once the face is worn off it won't last long.
Buy a new set - good for the next 6k miles at least! |
Bartlett 914 |
Oct 20 2009, 09:33 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
You can clean them with a very light ( 600 grade) emory paper, but once the face is worn off it won't last long. Buy a new set - good for the next 6k miles at least! I was always under the understanding that sanding (enory parer including) contacts was bad. Maybe a file but not sanding. |
oldschool |
Oct 20 2009, 09:38 PM
You can clean them with a very light ( 600 grade) emory paper, but once the face is worn off it won't last long. Buy a new set - good for the next 6k miles at least! I was always under the understanding that sanding (enory parer including) contacts was bad. Maybe a file but not sanding. I was talking about the injection unit not the dizzy? |
Lo-Fi Version | Time is now: 10th May 2024 - 11:25 AM |
