| tuff914 |
Oct 23 2009, 02:06 AM
Member ![]() ![]() Group: Members Posts: 67 Joined: 6-May 08 From: Australia Member No.: 9,020 Region Association: None |
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket handle. Anyone know of a trick to cracking it. Thanks in advance John |
| cwpeden |
Oct 23 2009, 02:58 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Take out the cotter pin?
Or a good solid impact gun. |
| zymurgist |
Oct 23 2009, 06:37 AM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
PB Blaster (or your equivalent penetrating oil) and an impact gun are probably your best bets. Leverage may not be enough... if you don't have an impact gun, use the penetrant and whack the nut with a hammer and brass punch (don't hit the threads) to try and work the penetrating oil into all the crevices.
| SLITS |
Oct 23 2009, 08:08 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
1/2" breaker bar, socket and about a 3' section of pipe as a cheater bar. Jump on the cheater bar with all your weight ... you may break the breaker bar though.
Impact gun works the best (most of the time). |
| tradisrad |
Oct 23 2009, 08:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
That bolt is torqued to 250 lbs. It can be tough to remove. I used an impact gun to remove mine, but my impact gun would not remove one from my second 914 and i used about a 4' bar and jumped on it. Are you replacing the wheel bearings?
I just torqued mine last night and that was a ton of fun. |
| GeorgeRud |
Oct 23 2009, 08:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I also found that a metal pipe that's fitted over my breaker bar (Craftsman of course) lets me remove the nut. I used a 4 foot piece of pipe, and if you break the breaker bar, you can always return it for a new one.
Remember, torque is force x distance in this case, so a 100 lb. weight 4 feet from the pivot will be 400 ft lbs, so you should be able to get it to come off with enough PB Blaster (or my favorite, Kroil), heat, and bouncing on the bar! |
| Gigamight |
Oct 23 2009, 10:12 AM
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
Sorry to hijack, but I was going to start a similar thread myself, except I think I did things in the wrong order. I have no brakes attached, and the tranny is out of the car and I am trying to get the dang nut off now. Any suggestions on how to keep the hub from spinning other than putting the tranny back in and the wheels back on and taking it off jack stands?
| aircooledtechguy |
Oct 23 2009, 10:47 AM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
This is the tool I used to remove these from a parts car. They will hold the hub against the ground while you use a long breaker bar.
They're called a Helping Hand Tool |
| brp986s |
Oct 23 2009, 10:52 AM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
If you're hopping on your cheater and your breaker snaps get ready to do some fancy footwork. I didn't want to risk it so I got craftsman 3/4 " breaker and sockets. However, the weak point of the 3/4" breaker is no stronger than the 1/2" breaker. Thanks for nothing. Seems craftsman is going harbor freight on us.
| Cap'n Krusty |
Oct 23 2009, 11:29 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I use a 4 ft long piece of 2 inch angle iron, drilled for 2 lug bolts. Propped against the ground, it provides plenty of counter force for the socket, breaker bar, and "extension" (cheater). My bar is drilled for numerous applications, such as flywheels, 4 and 5 lug drums/rotors, front pulleys, and such. The Cap'n
| GeorgeRud |
Oct 23 2009, 12:26 PM
I forgot to include in my post that you do need to have some way of holding the hub stationary.
I also drilled angle iron to fit over the studs on my 914-6 to hold the hub stationary by having the long end resting on the ground. When I went to remove the nut, it did put a slight bend in the bar as well. At least with the Craftsman tools, you can return them when (not if) they break. They definitely went Harbor Freight a good number of years ago! |
| Elliot Cannon |
Oct 23 2009, 01:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Use a 3/4 inch breaker bar, a 4 foot extension pipe. Have someone apply much pressure/weight etc. at the end of the cheater. Use a BFH on the cheater bar about where the end of the breaker bar is. Spit in one hand and then rub it into the other hand. Lift up the hammer and yell "OK you muther effer, you are coming off NOW". Stare at the point you want to hit and using that "keep your eye on the ball technique" hit that sucker a good whack. This of course is all done after using PB plaster or some other penetrant. Good luck.
Cheers, Elliot |
| DBCooper |
Oct 23 2009, 01:42 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
If you've done all of the above and that pig still hasn't budged then kneel and pray.
If that doesn't work then throw it in the truck and take it to any local truck repair shop (look it up). Have them take their 3/4" impact gun to it. It will take them no more than 5 seconds and won't even look like it was stuck. (IMG:style_emoticons/default/biggrin.gif) Keep this in mind when you're bouncing up and down on that 4 foot cheater on your breaker bar and wondering just when the whole thing's going to snap and where and how hard that's going to dump you. (IMG:style_emoticons/default/blink.gif) |
| 6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
BIG BALLS (IMG:style_emoticons/default/lol-2.gif) IF YOU DONT HAVE THEM TAKE YOUR NUTS FROM YOUR WIFES PURSE ,SPRINKLE SOME WATER ON THEM AND GROW A PAIR (IMG:style_emoticons/default/lol-2.gif) ..Caps (IMG:style_emoticons/default/headbang.gif) ..just poken ya man ...those things are a bitch ,good luck
| jhadler |
Oct 23 2009, 03:32 PM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Keep this in mind when you're bouncing up and down on that 4 foot cheater on your breaker bar and wondering just when the whole thing's going to snap and where and how hard that's going to dump you. (IMG:style_emoticons/default/blink.gif) I would recommend against actually jumping on the bar. A sustained weight on the end of a long lever arm is safer. 4' steel pipe, you wouldn't even need to put all your weight on it. -Josh2 |
| VaccaRabite |
Oct 23 2009, 04:03 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
If you're hopping on your cheater and your breaker snaps get ready to do some fancy footwork. I love that feeling. You see it happen. Time slows to the point where you are sure you have enough to take corrective action. The tool snaps, part breaks, etc, and from that point you are your own passenger as you stumble backwards through the garage, eventually tripping over something and going ass over teacups. Its the extreme apparent slowness that is so interesting. It may be all over in a second, but at the time it seems to go on an on. Zach |
| jhadler |
Oct 23 2009, 06:09 PM
Except for the part that actually broke under load. It will tend to depart the scene of the crime at a great velocity. Hopefully it simply overtakes you and it imbeds itself in the wall before you reach it. Otherwise, it might imbed itself in you...
-Josh2 |
| Jeffs9146 |
Oct 23 2009, 06:44 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I went to a tool rental place and rented a 3/4 impact gun and hooked it to my compressor!
(IMG:style_emoticons/default/aktion035.gif) |
| DBCooper |
Oct 23 2009, 09:18 PM
Now THAT'S what works!!! More horsepower, cures everything. Works if you have the trailing arms out as well.
| type2man |
Oct 24 2009, 05:51 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
![]() Problem solved.....36mm welded onto an iron bar with a slight angle to clear flares. |
Lo-Fi Version | Time is now: 5th April 2026 - 03:08 PM |
